Anti theft door braces
Postby griffo » Mon Mar 19, 2018 8:08 pm
With the spate of thefts from vans where they bend the doors down, side doors seem a common entry point also on Hitop Transits the rear door hinge point is far too low which makes them more sucseptible to attack in this way, so I was prompted to stiffen the doors up with some home made braces.
I got some 1" box section and welded it top middle and bottom of both the rear doors and similarly for the side door, the only real problem I had apart from the unbelievably shitty thin steel the doors are made of was with the side one.
The clerance as the door opened was too tight at nearly fully open for the 1" box to miss the side of the van so I dad to slice the box section open and re weld it together a bit thinner.
I am no fabricator but at the end of the day the doors are far sturdier and I feel slightly happier now when I have to park the van out of my sight!
If I could just get the rear doors to lock 9 times out of 10 instead of 3 times out of 10 I would be much happier.
griffo
Re: Anti theft door braces
Postby Punto443 » Mon Mar 19, 2018 9:58 pm
Probably a knackered wiring loom tho the rear door, they break up inside the plastic tube.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby griffo » Mon Mar 19, 2018 11:10 pm
Punto443 wrote:Probably a knackered wiring loom tho the rear door, they break up inside the plastic tube.
Best way to test them, continuity and flex the cable or insulation resistance tester?
griffo
Postby Herts » Tue Mar 20, 2018 8:45 pm
Griffo- do you have any pictures?
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby griffo » Wed Mar 21, 2018 3:27 pm
Herts wrote:Griffo- do you have any pictures?
Andy
I can take some, not sure how to upload to the forum though?
griffo
Postby MinorMatt » Tue Mar 27, 2018 2:55 pm
You could have welded the bars in to the window recess rather than worrying about the clearance
Return to Transit Talk
