lower ball joint
lower ball joint
Postby Anth009 » Sat Jun 09, 2018 7:17 pm
how do you remove bottom ball joint from the wish bone not replacing it but need to replace the drive shaftboot
Anth009
Re: lower ball joint
Postby ned » Sat Jun 09, 2018 7:35 pm
Ball joint splitter. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Anth009 » Sat Jun 09, 2018 7:38 pm
ned wrote:Ball joint splitter. N
never tryed ome but had it at a garage and they couldnt remove it
Anth009
Postby ned » Sat Jun 09, 2018 7:53 pm
Are you just trying to pop it out of the wishbone?
You can either use a wedge type splitter that you hammer in or get a big bar and lever the wishbone down. N
ned
Postby Anth009 » Sat Jun 09, 2018 7:57 pm
ned wrote:Are you just trying to pop it out of the wishbone?
yes tryed levering it its solid in wishbone havent got a splitter al get 1 tomorrow thanks
Anth009
Postby ned » Sat Jun 09, 2018 8:32 pm
I use one of these,
https://m.ebay.co.uk/itm/Heavy-Duty-8-B ... SwXOVaivkB
Never let me down yet, except the time I snapped one fork :roll: N
ned
Postby twin wheel camper » Sun Jun 24, 2018 9:58 pm
Don’t use the type in the link unless your replacing the ball joint because it will destroy the rubber :!:
You stated you aren’t replacing the ball joint so you need to buy or borrow the type that won’t split the rubber.
twin wheel camper
Postby ned » Sun Jun 24, 2018 10:27 pm
Yes don't split your rubber :wink: we all know what happens when you have a split rubber :lol: ball joints are cheap enough to replace. N
ned
Return to Transit Talk
