Been for MOT last week and told mechanic steering veers to the left sharply...said ball joint was the cause yet one side is markedly lower than the other...took it too another garage who fitted the ball joint...no friggin difference,couldnt be arsed to test the van to see if it had corrected it...all they want is your money then f*** you off.Went to ATS for a second opinion and asked them if it could be tracking but basically didnt have a f*** clue either...brainwashed bloody robots...so i did some research on line and found this:
1. Vehicle is tilting to one side
One of the duties of the suspension springs is to keep the vehicle balanced on equal sides. When a spring has collapsed or is showing signs of premature wear and tear, one of the common side effects will be that one side of the car will appear to be higher than the other side. When you notice that the left or right side of your vehicle appears higher or lower than the other side, have a local ASE certified mechanic inspect and diagnose the problem as this can affect steering, braking, and acceleration among other problems.
