MinorMatt wrote:Looks interesting.... but no
I would imagine a heated screen would be much better though?
Mike wrote:Has anyone tried the Heat Shot windscreen washer heater? It heats a small amount of washer liquid in 30seconds, so helps clear ice in the winter and seems to do a better job of clearing grease and bugs in warmer weather.
It took about 40mins to fit http://www.heatshot.com/uk/
Punto443 wrote: From around £75 upward, and a legitimate business expense as well Al
Altransit wrote:
Where did you find them for £75![]()
They were around £250, and they were doing a 'show special' for £200![]()
ME wrote:When I started my mechanic apprenticeship in 1981 the garage I was at had a petrol fourcort as well, in the shop they sold a kit that was a small saddle like tank that was secured to the top hose then joined between the washer bottle and jets. Loads of people had them fitted, they were pretty useless, rather like this thing Mikes fitted![]()
Look at along the lines of
A cup full of warm water hits a frozen windscreen and ........ freezes on contact. By which time you have no rubber on your wiper blades because they were stuck to the windscreen by the frost.. or you blow the fuse for the motor. If it's fitted to a mark 7 you will blow the fuse when you try to replenish the water to the unit if its coldfuse roulette
If someone could come up with a proper working solution to the frosted windscreen/ frozen jets/ frozen washer bottle etc and be able to keep a windscreen clean no matter what the weather. They would a rich person
