Heat Shot-windscreen washer heater.
Re: Heat Shot-windscreen washer heater.
Postby dumper » Sun Dec 02, 2018 2:36 pm
On a mk3 I had I needed a new washer bottle got one from scrapyard it had a head light washer pump as wel I piped it up with the pipes attached to the wiper arms without jets on the end always worked when washers had froze down side used a lot of water
dumper
Postby Mike » Sun Dec 02, 2018 2:44 pm
That’s a rallycross trick
Mike
Wind up merchant!
Postby bambi mk 1 » Sun Dec 02, 2018 5:21 pm
dumper wrote:On a mk3 I had I needed a new washer bottle got one from scrapyard it had a head light washer pump as wel I piped it up with the pipes attached to the wiper arms without jets on the end always worked when washers had froze down side used a lot of water
I know someone who used one for 2 extra jets on a mk 3 directed to the left aimed directly for hairdressers in soft tops :mrgreen:
bambi mk 1
Postby Altransit » Sun Dec 02, 2018 11:52 pm
Altransit wrote:Cheers Mike, that's a much better price. I'll get one on order :mrgreen:
It's here, I'm going to fit it to the Focus which already has heated jets, and a heated screen, so in theory, it will always work.
I need to find the heated jets for the Mk7, and fit those, before fitting another one to this, or maybe I'll fit the budget version instead :lol:
Postby Mike » Mon Dec 03, 2018 9:10 am
If you use this https://www.holtsauto.com/prestone/prod ... creenwash/ nothing will freeze.
Mike
Wind up merchant!
Postby ake » Thu Dec 06, 2018 9:18 pm
Mike wrote:If you use this https://www.holtsauto.com/prestone/prod ... creenwash/ nothing will freeze.
Good stuff that, works a bit like Rain C as well, the rain beads and runs up the screen at motorway speeds, don’t even need the wipers!
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
Or is it something worse?
Postby Mike » Thu Dec 06, 2018 9:32 pm
This https://www.cleanyourcar.co.uk/gtechniq ... ealant-kit is good too, it’s lasted 18months so far and seems to work at lower speeds than Rain X etc
Mike
Wind up merchant!
Postby Altransit » Fri Dec 07, 2018 12:05 am
Mike wrote:This https://www.cleanyourcar.co.uk/gtechniq ... ealant-kit is good too, it’s lasted 18months so far and seems to work at lower speeds than Rain X etc
Looks good :D
How far does it go Mike, i.e. is 15ml only enough for one screen? How often do you need to apply it?
Postby Mike » Fri Dec 07, 2018 9:10 am
Looks good :D
I’ve done two windscreens and four side windows and there’s still some left. Gtech seem to be quite generous in their estimations.
Mike
Wind up merchant!
Postby Mike » Thu Jan 31, 2019 2:15 pm
Hotshot is performing well, although the Prestone screen wash is the colour of piss and makes it look like someone has relieved themselves on my bonnet. Yellow snow :mrgreen:
Mike
Wind up merchant!
Postby MinorMatt » Thu Jan 31, 2019 6:36 pm
I couldn't find anywhere to put it in the volvo :(
95 M Ford Prototype/Mule DRW 100PS Highcube
96 N 120 Turbo'd DI SWB Low
Lucas laser 2000 & IDS onwner
Postby Mike » Thu Jan 31, 2019 7:07 pm
MinorMatt wrote:I couldn't find anywhere to put it in the volvo :(
You’d think there’d be more room under a Volvo bonnet than a Connect.
Mike
Wind up merchant!
Postby MinorMatt » Sat Feb 02, 2019 10:39 pm
Don't know... 5 cylinder transverse engine not a lot of easily available space - even with battery in the boot
Return to Transit Talk
