Reverse Camera Suggestions
Postby Knobby2515 » Thu Jan 07, 2021 8:03 pm
Do you have a MK7?
Do you have a reverse camera?
If so what one have you got?
Am after some suggestions
2012 MK7
100 T330 2.2 with 150hp Vanunter upgrade
MWB Semi-high roof
2.2 - 6 speed RWD
Air-con, heated screen, front fog lamps, cruise control, twin slide doors
Knobby2515
Re: Reverse Camera Suggestions
Postby Noctule » Thu Jan 07, 2021 11:01 pm
Android 8.0 head unit with reverse camera function. I don't think I'd get another, the build quality is poor (the fascia lights have failed and I had to butcher its mounting & the hole in the dash to fit) and lots of apps won't work on the routed operating system e.g. BBC Sounds and All4. You can bluetooth music to it but you have to allow calls through it to do so, despite already allowing music. Digital works on it with usb dongle, but reception is poor.
It's nice that the screen is in the dash for reversing (one less screen), but it's in the wrong place for using it as a satnav.
Mat
2012 Mk7 125t350 camper conversion in progress
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 190 HiCube DRW self-built camper
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Knobby2515 » Fri Jan 08, 2021 3:53 pm
Noctule wrote:Android 8.0 head unit with reverse camera function. I don't think I'd get another, the build quality is poor (the fascia lights have failed and I had to butcher its mounting & the hole in the dash to fit) and lots of apps won't work on the routed operating system e.g. BBC Sounds and All4. You can bluetooth music to it but you have to allow calls through it to do so, despite already allowing music. Digital works on it with usb dongle, but reception is poor.
Mat
hmmm sounds like one to avoid
2012 MK7
MWB Semi-high roof
2.2 - 6 speed RWD
Knobby2515
Postby Noctule » Fri Jan 08, 2021 8:55 pm
It's a good unit deep down, just poorly executed in a few areas. A newer version of Android might be better (it's a few years old now), and the DAB box needs a proper aerial rather than the film type in the windscreen.
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby bortaf » Sat Jan 09, 2021 3:52 pm
I have the below android 9 unit, it has auto on to the rear camera when Rev is enguaged, the standard camera was fine but i replaced it with one with IR emitters and better night vision, the camera i used was part of a 4 cam CCTV system i instaled and just used a splitter cable on the Fr and Rr cameras, you can go to the Fr cam with a button press and as Fr and Rr are IR i can drive in the dark with no lights on in case of Zombies :lol:
Works fine as satnav, in a Mk7 it's in an OK pos :)
Android 9 Double Din Car Stereo For Ford C-Max/Connect/Fiesta/Focus/Fusion/Galaxy/Kuga S-Max/Transit/Mondeo Schwarz GPS Navigation Head unit |2G+32G 7 Inch| WIFI Google Bluetooth Backup Camera&Canbus
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Return to Transit Talk
