Transit pre2014 diesel use high
Postby Groovejet » Thu Jan 14, 2021 5:31 am
The same 5 hr return journey in two similar vans, there was a difference of £30 in diesel.
My van cost £80, other van was £50. What could be issue? Massive differance
Groovejet
Re: Transit pre2014 diesel use high
Postby hughesyn » Thu Jan 14, 2021 11:36 am
Are they both the same height? (H3 uses more fuel than H2 at motorway speed)
Tyres inflated properly?
Same weight on board?
Both the same engine and final drive?
If all these factors are similar, the mpg should be similar.
There's not many faults that have a big effect on fuel consumption (on a diesel), because if the fuel is being burnt, it's producing power.
Maybe a fault causing excessive DPF regen?
2023 Mk8 DCIV 170 auto L3H2
hughesyn
Postby dumper » Thu Jan 14, 2021 3:32 pm
Be a good idea if you also posted van spec and have you worked out the mpg as well as just the cost as hughesyn says vans need to be the same to get a true comparison.
Postby Groovejet » Fri Jan 15, 2021 9:50 pm
Heres the Spec. of the Transit.
Transit 2009/59
SWB 2.2TDCi (85ps) 280 Medium Roof (FWD)
Normally van is rammed with every tool known to man. But a great lot of tools was removed before jouney. Shelves were still loaded with glues, silicones, plumbing stock, so add it up, it probally weighs abit tbh.
But still! £30 differance is alarm bells. Even if it was a Transit v's Merc. Sprinter....£30?? surely that still wouldnt be right?
Groovejet
Postby Altransit » Fri Jan 15, 2021 11:24 pm
Groovejet wrote:Heres the Spec. of the Transit.
Transit 2009/59
Pretty much the same as my Transit.
£80 of fuel would take me anywhere between 400-500 miles, depending on how hard (fast) I drive it, but if you're a pedal to the metal, hard braking, kind of guy, it will probably do much less than that.
I have managed to get over 600 miles from a full tank (just once) running it almost to empty :shock:
Postby andz327 » Sat Jan 16, 2021 12:50 am
57plate lwb m/roof fwd gets me 500 - 650mls per tank using shell
ANDZ
andz327
Postby Groovejet » Sat Jan 16, 2021 3:18 am
yes must admit i do brake late and all of that. Although i dont drive stupid but i call it confident driving. Idont go slow and dont go silly. Only reason i go slower around corners is because all my tools end up on van floor if i do..lol
Groovejet
Return to Transit Talk
