iam gona have a go at making my own quad lamps for a transit
Postby intransit89 » Sun Oct 14, 2007 10:55 am
as it says^
mk4/5
use the normal mk4/5 lights but take the front of and from the in side fill it with fiberglass
and put 2 of them lights i get in the mk1 or minis i would say wot lamps i mean but for got
oh and drill the holes for the lamps in the fiber glass wot you think
so i think i will need the both side of the front lamps but i have a drivers side any way :)
just need some fiberglass from my local car shop and will see :)
intransit89
Re: iam gona have a go at making my own quad lamps for a transit
Postby djswampy » Sun Oct 14, 2007 2:21 pm
Would the fibreglass not melt?
djswampy
Postby intransit89 » Sun Oct 14, 2007 2:32 pm
djswampy wrote:Would the fibreglass not melt?
well thay maded the quad lamps for transit out of fibreglass didnt thay? :!:
intransit89
Postby djswampy » Sun Oct 14, 2007 2:43 pm
dunno. I just thought the resin might melt. I thought headlights were made out of either an ABS polymer or a thermoset.
djswampy
Postby intransit89 » Sun Oct 14, 2007 2:45 pm
djswampy wrote:dunno. I just thought the resin might melt. I thought headlights were made out of either an ABS polymer or a thermoset.
i ant a clue will see wot the others say before i waste my time tho :D :|
intransit89
Postby poppajoe » Tue Oct 16, 2007 10:33 am
No Worries, it won't melt....
Fiberglass is "Polyester" resin which has a higher melting point than both ABS and thermoset and when coupled with glass the temperature is quite high.
If you want the tech info on any plastics look here -
http://www.ensinger.ltd.uk/tech_data_sheets.html
Polyester is listed as "tecapet" or "PET"
And yes, I do work for them.....
Hope it helps :wink:
poppajoe
Postby intransit89 » Tue Oct 16, 2007 11:57 pm
thank you nice for the help
now i forgot wot you call them lamps you buy for austin minis or mk1 transit or mk1 escort that when thay blow you tho the lamp a way and put a other one in ?
:idea:
intransit89
Postby AndyG » Wed Oct 17, 2007 12:09 am
Do you mean; sealed beam :?:
And Mini/Transit MK1/Escort one's will be too big :!:
You want some out of say, a Rover P6 or Triumph Dolomite and the like :wink:
Postby intransit89 » Wed Oct 17, 2007 12:22 am
Andyg wrote:Do you mean; sealed beam :?:
i thats them sealed beam
intransit89
Postby intransit89 » Wed Oct 17, 2007 12:24 am
would you say 4" do the trick? to fit two? in one lamp?
intransit89
Postby intransit89 » Wed Oct 17, 2007 12:38 am
is there a frame so you can screw it on and than put bulb in? or are thay just one light jobby?
:idea:
intransit89
Postby AndyG » Wed Oct 17, 2007 12:43 am
:idea: You need to go to the scrappy and buy a pair :wink:
Postby intransit89 » Wed Oct 17, 2007 12:45 am
Andyg wrote::idea: You need to go to the scrappy and buy a pair :wink:
so i need 4 all together :)
intransit89
Postby Altransit » Wed Oct 17, 2007 12:47 am
I think the smaller size sealed beams were 5 inch, the big ones were 7 inch :wink:
Postby poppajoe » Wed Oct 17, 2007 2:08 am
Try a twin lamp capri or triumph dolomite?
poppajoe
Return to Transit Talk
