Thought I'd post this separately so it's easy to find.
There was some confusion on a recent thread about maximum wattage allowed for headlamps, and there is a common misconception that you are only allowed 55 watt bulbs.
Schedule 4 of the Road Vehilces Lighting Regulations 1989 states
8. Wattage-
(a) A motor vehicle with four or more wheels first used on or after 1st April 1986: No requirement
(c) A motor vehicle with four or more wheels first used before 1st April 1986: 30 watts minimum
However, it also states:
5. Markings-
(a) Any vehicle not covered by sub-paragraph (b), (c) or (d): An approval mark or a British Standard mark
(b) A motor vehicle first used before 1st April 1986: No requirement
(c) A three-wheeled motor vehicle, not being a motor bicycle combination, first used on or after 1st April 1986 and having a maximum speed not exceeding 50 mph: No requirement
(d) A solo motor bicycle and a motor bicycle combination: No requirement
There is in fact, no regulation as to maximum or minimum wattage for headlamps, (other than that vehicles used before 1st April 1986 require 30 watts minimum) HOWEVER, on any vehicle used after 1st April 1986 the bulbs must carry an approval mark i.e. kite mark or ec marking, and you will struggle to find high wattage bulbs with an approval mark.
The offence you would commit is using bulbs without a type approval mark, for which Plod would have to a) know this information, and b) remove your bulbs to check, and it would probably only result in a bit of advice or a vehicle defect rectification notice anyway, unless the lamps were adjusted in a way that they caused dazzle, which is a separate offence and would make any difference what wattage your bulbs were.
The good news is, if your van is pre 1986 the only stipulation is that your bulbs must be at least 30 watts, there is no maximum limit!
Full schedule can be found here:
http://www.opsi.gov.uk/si/si1989/Uksi_1 ... _9.htm#end
