Fat tyres,tires,tiers
Postby loot » Mon Jul 01, 2024 12:21 pm
Hey Ned, AT Tyres or tires as we now call them :roll:
The daddy i guess are BF Goodrich or (michelin) right 235 65 17 which are 4x4. But will be ok on the new van (mk7)
What's your opinion on cheaper ones? Road kruzer etc. Bf are like 800 for 4 new, i can get cheap ones as low as £69 each but don't fancy using the chalk on the side walls to show rubber dub or whatever gash name there is :lol: I could still put bf goodrich on there but it won't be good and I'll only be lying to myself.
General grabber seems reasonable as I'm familiar with them but still...
Ids map here
loot
Re: Fat tyres,tires,tiers
Postby ned » Mon Jul 01, 2024 5:01 pm
Why hello,
Yes bfg’s are bloody expensive, mr Airthies has them, I’m currently running powertrac vantour m&s on fanny, low road noise and surprising quite grippy considering how cheap they were, I had gerneral grabbers once but they were super loud road noise, maxxis look quite good but expensive now.
What wheels are you fitting them on? Depending on the back space (et offset) depends on whether they’ll catch or not, when I had 235’s with a 4” backspace they caught the arches.
We have powertrac on the Alfa as well and wet grip is good.
It’s really a trade off of what your needed them for, proper A/T are great in muddy but noisy on tarmac, m&s are quieter but not great in mud.
Whichever ones you go for look miles better on the mk7 then the standard ditchfinders
Look at those fat bitches filling the arches
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Mon Jul 01, 2024 9:25 pm
I'm getting 17 inch wheels, I think et45.
Standard is 215 75 16, 225 65 17 compared virtually the same diameter but a midges wider and 235 a midges more but still ok i think. I'm fitting these wheels.
I noticed bf 02 somethings were off road only. I only drive on the road but I like the look of the extra grip on the side walls, i may occasionally go camping etc but mostly I want good road tyres really.
Ids map here
loot
Postby ned » Tue Jul 02, 2024 7:04 am
Ooooow there nice 8) there’s a merc camper near me with similar wheels and bfg’s with the side wall tread, I’ll try and get a sneaky picture.
Et45 that’s pretty similar to the standard factory wheels isn’t it, as long as it clears the chassis rail you shouldn’t have a problem
The best thing I can say is when comparing tyres look at the db rating, the constant droning noise will drive you mad after awhile.
The better the brand the longer they should last unless you get magnetic tyres like Mr Punto had on his mk7 :lol: :lol:
Good luck and Godspeed
ned
Postby loot » Tue Jul 02, 2024 9:21 am
ned wrote:Ooooow there nice 8) there’s a merc camper near me with similar wheels and bfg’s with the side wall tread, I’ll try and get a sneaky picture.
Cheers, i have the rwd t330 so it'll have more clearance than the fwd, snowflake used to enjoy 255 55 18 I think, t350. Used to be fine apart from inner scrub on full lock which i set the toe to parallel to fix that :P
I may end up with road tyres on but I'm going for the off road camper look on the van.
But certainly I'll look at db rating. I'd expect if the tread pattern looks more road then it should be road worthy, some patterns look like mushrooms or something :lol:
Ids map here
loot
Postby ned » Tue Jul 02, 2024 11:55 am
If I didn’t have wellers there the style of wheel I’d go for, you know the rugged look, have you fitted them yet :lol: if snowflake had wider tyres then 235’s shouldn’t be an issue, remember you need a limited slip diff on that rwd, donuts anyone
ned
Postby Altransit » Tue Jul 02, 2024 2:19 pm
It's all gonna end in tiers :mrgreen: :P :shock: :lol:
Postby ME » Tue Jul 02, 2024 5:12 pm
Are all these “Big Tyres “. Steel belted now ? Many years ago they were fabric, almost Cross ply construction.
Mercedes Vimto Premium
ME
Postby loot » Tue Jul 02, 2024 10:33 pm
I'd like to think they won't come off when I bunny hop a sleeping policeman :P
The look I'm going for would kind of be like that van off tango and cash line of thing but not quite as lairy and no guns :lol:
Ids map here
loot
Postby andz327 » Wed Jul 03, 2024 9:11 pm
https://www.ebay.co.uk/itm/256051189082 ... media=COPY
andz327
Postby andz327 » Wed Jul 03, 2024 9:21 pm
Go 75s
https://www.ebay.co.uk/itm/335194850456 ... media=COPY
andz327
Postby andz327 » Wed Jul 03, 2024 11:51 pm
https://www.ebay.co.uk/itm/296034640774 ... media=COPY
andz327
Postby loot » Mon Jul 08, 2024 9:31 pm
andz327 wrote:https://www.ebay.co.uk/itm/296034640774?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=PP2ATC5rSve&sssrc=4429486&ssuid=Ja_Kz6u0RrC&var=&widget_ver=artemis&media=COPY
These look good and they're called churchill :P if I use the coupon it'll be £299 for 4
72db is good isn't it
Ids map here
loot
Postby andz327 » Mon Jul 22, 2024 11:31 pm
These look good and they're called churchill if I use the coupon it'll be £299 for 4
It's around same as normal transit tyres mate between 70-72
andz327
Postby loot » Wed Jul 24, 2024 3:11 pm
Sweet I've got a way to go before buying the wheels, never know they might invent hoover wheels by then :lol: :lol:
Ids map here
loot
Return to Transit Talk
