any1 used it or is it best avoided ? it's for the spare tyre as the tread is like new
plus how long would it last would help
charly wrote:it has a nail on the edge of the tread, one of the local garages refused to even take the tyre off
yes it's my spare
Smooth Hound wrote:You would be better off getting a patch put on the inside of the tyre, or putting a tube in it, ...
toriitom wrote:Smooth Hound wrote:You would be better off getting a patch put on the inside of the tyre, or putting a tube in it, ...![]()
IIRC under BS AU159 it is now illegal to fit a tube into a tubless tyre. Also, if you are going to patch the tyre from the inside you must use a 'mushroom' plug & patch; this type of repair is the only legal method of fixing tubless tyres.
MARTYN5 wrote:The trouble with foam type tyre inflators is that you dont know how many punctures you actually have ( depending on what you have run over ) as they plug all of them. If the puncture is on the shoulder mushroom plugs were not to be used when i was in the tyre trade, because of the complexity of the cords a proper vulcanized major repair is the only option.
motorwise wrote:MARTYN5 wrote:The trouble with foam type tyre inflators is that you dont know how many punctures you actually have ( depending on what you have run over ) as they plug all of them. If the puncture is on the shoulder mushroom plugs were not to be used when i was in the tyre trade, because of the complexity of the cords a proper vulcanized major repair is the only option.
if the puncture's on the edge the tyre is scrap
