Loot
Loot
Postby ned » Thu Jul 16, 2026 6:28 pm
Can’t find the set up of the gauges on the old oil cooler or find the old oil cooler any how hope this make sense.
The bent fitting at the top is going to be screwed into the oil pressure sensor hole
The pressure gauge is at the bottom
The temp sensor is on the right
All the gubbins on the left are just so I don’t lose the bits but the vans pressure sensor will go in that side
This is the nipple for the boost gauge that I fitted on the pipe from the intercooler to the manifold
Hope that make sense
Note the pictures are on there side so the top is the left
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Return to Transit Talk
