WHIRRING NOISE IS IT MY PUMP
Postby billtee » Wed Feb 06, 2008 12:14 am
As you can remember my fan belt shredded and got round my crank and lifted my cam belt and timing went out and wrecked my top end :cry: :cry: . Any way were up and running again with no cost to me :lol: Motor factors paid for most of my bits .Anyway now i've got a whirring sound related to engine speed and it's not the cambelt tensioner i've fitted a new 1.I'VE got a bosch pump i'm wondering weather the excessive tension the cambelt recieved could of strained the pump bearings any info would be appreciated thanks again everyone.
billtee
Re: WHIRRING NOISE IS IT MY PUMP
Postby MrMPuk » Wed Feb 06, 2008 12:33 am
When start a post with as you can remember it means you should probably reply to your original thread. There is over 5000 members on here and they all have problems and not everyone has the memory of an Elephant!
Postby billtee » Wed Feb 06, 2008 1:08 am
ok m8 but i've re- described my original problem in this new post thanks.
billtee
Postby MrMPuk » Wed Feb 06, 2008 1:10 am
Well you've not given any details on what year and engine, so like I say a big guessing game!
Postby billtee » Wed Feb 06, 2008 1:18 am
ok it's a 1999 2.5di 100 lwb semi hi top van .Hope this helps i will remember next time to start off with more info .SORRY 8)
billtee
Postby MrMPuk » Wed Feb 06, 2008 1:20 am
Have you tried running it with the alternator belt off?
Postby rover » Wed Feb 06, 2008 9:13 am
What make of auxilliary belt have you fitted? Some of the cheap ones do tend to 'whirr'
Like MrMPuk says, drop the belt off and see if it still makes the noise, that will cut your options in half straight away :wink:
Rover.
rover
Postby billtee » Wed Feb 06, 2008 9:36 am
All the belts are brand new and the alternator is also brand new ,the make of all the belts are unipart.Water pump has no play in it and it's not weaping also power steering pump seems ok any help will be appreciated i think it's ethier cambelt or pump as cambelt tensioner is also new,thanks again
billtee
Postby poppajoe » Wed Feb 06, 2008 10:26 am
Is the auxillary belt not just too tight?
poppajoe
Postby MrMPuk » Wed Feb 06, 2008 12:03 pm
billtee wrote:All the belts are brand new and the alternator is also brand new ,the make of all the belts are unipart.Water pump has no play in it and it's not weaping also power steering pump seems ok any help will be appreciated i think it's ethier cambelt or pump as cambelt tensioner is also new,thanks again
As said, run it with the alternator belt off!
Postby billtee » Wed Feb 06, 2008 11:42 pm
The belts are not 2 tight and i've run it with alternator belt off and noise is still there
billtee
Postby billtee » Thu Feb 07, 2008 11:40 pm
Guess will wait and c then :shock:
billtee
Postby poppajoe » Fri Feb 08, 2008 1:00 am
cambelt rubbing somewhere?
poppajoe
Postby billtee » Sat Feb 09, 2008 7:41 pm
Thanks m8 it might be rubbing on the plastic cover i had'nt thought of that :D hope your right.
billtee
Postby poppajoe » Sun Feb 10, 2008 3:45 am
billtee wrote:Thanks m8 it might be rubbing on the plastic cover i had'nt thought of that :D hope your right.
No problem, but do post back to let us know.... :wink:
poppajoe
Return to Transit Talk
