the gardener wrote:Thanks AndyG for that comprehensive history, why aren't autoboxes more available on vans, is it gearing, build cost, maintenance / reliability, public acceptance or other issues?
Well, generally speaking, people always like to "save" money and autoboxes are usually an extra cost option
There are also a lot of narrow minded people with "funny" ideas
When auto boxes started life, they were quite primitive although quite a clever idea
The design was such, that they did sap a noticeable amount of power and therefore did use more fuel
As a result, they weren't generally offered on small engined/low output cars
We have come a very long way with autoboxes
so much so that BMC started offering auto on really small cars like the Mini and 1100/1300 range
To compensate for the very small output of these engines, they all had 4 speed boxes (not overdrive)
They proved quite popular and a lot of the "posh" Vanden Plas' left the showrooms with auto
The other problem that the autoboxes reputation suffered, was when they did give trouble, most so called mechanics would suck there teeth and recommend a complete and expensive (and usually not required) compete rebuild
So the owner would have to decide, either get it repaired, or sell it while it still goes
Now, this is the next stage of their reputation suffering
The new owner buys this faulty auto (not having a clue how they work or what signs to look out for) and soon discovers has a problem
Off he goes to his so called mechanic, which bodges it up and of course the owner starts the "autos are no good" syndrome
The Transit auto boxes also kept evolving
We had the 3 speed unit which was upgraded to a 4 speed overdrive with "lock up" torque converter for even greater fuel efficiency and even more relaxed motorway cruising
The overdrive ratio being slightly higher than that of the manual Transit
They never stopped there either
In their search for more efficiency, they went over to the partially electronically controlled version that adjusted the pressure rail of the oil pump so that the box wasn't at "full pressure" all of the time, as this was considered a waste of energy and a further saving to fuel/power can be made
Unfortunately this mod. did lead to the overdrive band burning out (lack of pressure) on some of these boxes (including mine
) and most would be out of warranty by then
Ford did release a mod for this and it's so simple to do, as it doesn't involve the box being removed
Heat generation is the number one killer of auto boxes
And I am looking into additional cooling for mine
One more thing
Some people think that autoboxes are just that
And for that reason automatically never need attention
Oils have improved over the years, but they would still benefit from an oil and filter change say 40 to 60 thousand mile intervals
Autoboxes have a lot of advantages over a manual box, not least the work load taken off the driver
If I was doing a lot of motorway driving, then this wouldn't really be an issue
