brakes
brakes
Postby blue meanie » Tue Apr 15, 2008 2:45 am
yesterday while vanning i came up on a slow moving truck.so slowed down without a drama.then the truck just stopped with no lights working on the damn thing :shock: .i threw out a verry large handfull of anchors and my rear end of the mk1 went violently sideways to the right.it has disc front,drum rear.i have never had this happen before.does any one have any ideas?.it allways stops in a safe fashion with good pedal feel.ta
I'D RATHER PUSH MY TRANSIT THAN DRIVE A BEDFORD
blue meanie
Re: brakes
Postby chris13 » Tue Apr 15, 2008 11:45 am
Have a look at the left rear wheel cylinder. That must be the one that didnt brake.
chris13
Re: brakes
Postby GARYBEGGS » Tue Apr 15, 2008 1:15 pm
If I were you I would consider using the new FM Brake Pads they give a fantastic Brake. The same company BBS also sell Brake Discs that are really good and the most reasonably priced parts I have seen. Pads are about £20 for the front wheel drive or rear wheel drive Transits and the Brake Discs are about £25 each.
If you would like to contact the company their name is Belfast Brake Specialists and the number is 02890 746436 or their website is http://www.ebrakes.co.uk
Hope this information is useful !!!!! :D
GARYBEGGS
Re: brakes
Postby blue meanie » Wed Apr 16, 2008 3:47 am
thanks for the replys folks.i adjusted the rear drums last night and find it still feels unsettled during panic stops.its better than before but allso have a slight grinding sound on the left rear.in normal braking situations it pulls up straight and safe but the grinding sound stays on for a bit after stoping.
blue meanie
Re: brakes
Postby chris13 » Fri Apr 18, 2008 8:56 pm
the wheel cylinders pistons should be able to move in and out rather easily, I bet yours are siezing, get a pair of new ones,and replace both sides, cos you will probably find at the mot it will brake unevenly if you dont.
chris13
Return to Transit Talk
