andy a wrote:At 14' long the bed will effectively give you about 13' when you take the winch into consideration, which isn't a lot to play with, also the bed looks like its all steel chequerplate which depending on what gauge was used could make it very heavy, remember the 3500kg weight limit includes the driver.
The ramps also look like their steel chequerplate, again heavy to be lugging about, and theres nowhere to stow them off the bed by the looks of it, which will be a right pain when loaded, also I cant see any lashing points in the photos, you really need bed mounted lashing rings to strap to, their a lot easier to work with than claws fitted under the bed sides.
You would also need a locker to store straps and othe crap in, which would add to the weight and the cost, and if that were my truck I would lose the headboard and put a proper flyer up front with something decent in it to stop a car coming through the back of the cab if the worst happened.
That said you would have to go and have a look at it to see if its any good, give it a proper look over and check the chassis out, theres a lot of tired rubbish about...
MrMPuk wrote:Dreamer
