3.0 Essex with 4 speed overdrive
Postby 214si » Sun Jul 20, 2008 9:08 pm
what is generally the top speed of one of these in 190 form??
also whats a comfy motorway cruising speed without screaming the arse of of it?
214si
Re: 3.0 Essex with 4 speed overdrive
Postby Luke » Sun Jul 20, 2008 9:49 pm
depends on what rear diff it's got :D
Postby 214si » Sun Jul 20, 2008 10:21 pm
bugger thats the reply i was dreading! well it does 70mph with the derv lump in it?? any ideas what my diff ratio is?
214si
Postby MrMPuk » Sun Jul 20, 2008 10:23 pm
You thinking about taking the 2.9 out and replacing it with the essex?
Postby Luke » Sun Jul 20, 2008 10:25 pm
214si wrote: any ideas what my diff ratio is?
have a look on the diff there should be a tag on it with the ratio - might need a bit of cleaning with a wire brush to read it tho :D
Postby sidspop » Sun Jul 20, 2008 10:34 pm
Bit of a vague question.
Speed is all dependant on a number of things, such as tyre rolling radius, diff ratio and even how well your tyres are inflated.
If you are very lucky you can read the tag, I've always found it easier to read back of the tag. A little bit of wire wool usually helps.
If that don't work, stick it in neutral, jack up one wheel, and count how mant turns of the diff flange you need to turn to do one full turn of the road wheel. You should be able to guestimate the ratio from that.
Andy
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby madmark » Mon Jul 21, 2008 12:06 pm
is or was the vehicle a factory 3ltr v6??????
Postby 214si » Mon Jul 21, 2008 3:36 pm
no it wasnt factory 3.0 it was a 2.0 pinto
yes im contemplating taking the 2.9 out and putting in an essex
214si
Postby MrMPuk » Mon Jul 21, 2008 4:44 pm
214si wrote:yes im contemplating taking the 2.9 out and putting in an essex
Are you mad?
Postby Luke » Mon Jul 21, 2008 6:55 pm
why :?:
Postby captain hook » Mon Jul 21, 2008 9:44 pm
You need to ask :lol:
captain hook
Return to Transit Talk
