Broken down
Broken down
Postby LondonYank » Wed Jul 30, 2008 10:57 am
Hi,
I've had my '01 lwb diesel for about 6 months now it has 142k miles and is in generally decent condition. Use it exclusively for transporting myself, two bikes and associated gear around the country for motorcycle racing. Coming back from Cadwell Park in Lincolnshire on Sunday night it nearly packed it in. On the way down the A1 I noticed it was a little down on power and would only pull 65 but wasn't too bothered as I figured I wasn't in a hurry and would save fuel. It wasn't until 100 miles later when I reached the A12 heading for the Blackwall tunnel that I really started to notice the total lack of power. Things got worse pretty quickly from there and nearly got stuck in the tunnel. Simply wouldn't get past 30mph and sounded really rough.
Started it up last night to see if anything obvious was amiss. The engine was somewhat hesitant to start but it did start. Ran really roughly and the steering wheel vibrated a fair bit. There didn't appear to be any exhaust leaks or other external engine issues. The oil level checked out ok.
While I know it's hard to diagnose the problem over the net I was hoping I could be pointed in the right direction. While I'm an okay mechanic on motorcycles I generally try to avoid working four wheeled vehicles. I fear that the engine is knackard and I will be looking for a new van.
LondonYank
Re: Broken down
Postby MrMPuk » Wed Jul 30, 2008 11:29 am
Start with the fuel filter.
Re: Broken down
Postby essex iain » Wed Jul 30, 2008 8:36 pm
soumds like a fuelling issue to me in my liumited knowledge - ive got something similar tho not as bad with my new tipper.....
essex iain
Re: Broken down
Postby robborm8 » Wed Jul 30, 2008 8:50 pm
Any smoke? what colour? :?:
robborm8
Re: Broken down
Postby jay » Thu Jul 31, 2008 6:52 pm
what engine power output is it??
Check there isnt any air leaks as that will reduce power..But does sound like fuel filter
mk1 connect tourneo
jay
Re: Broken down
Postby Dominik1968 » Sun Aug 17, 2008 12:15 am
Hi there. :D
Hope you got the problem sorted out,like the others have said try taking a look at the fuel fliter first as it does'nt take a lot for them to start to hold back once the filter is a little blocked up.My only other idea is that it might be the fuel pump itself. :( One of my drivers once got a Transit home over 200miles with a pump that would only get the van up to about 60mph.
Take care and safe miles. 8)
20,000 MILES AND COUNTING :!: :D [/img]
Dominik1968
GLX Posse
Return to Transit Talk
