v8 in a mk11
v8 in a mk11
Postby truckdoctor » Fri Aug 08, 2008 5:58 pm
Could a big block V8 be fitted behind the seats in a mk11 ?, a bit like supervan but done on the cheap ,not sure if theres enough length ,any ideas please
truckdoctor
Re: v8 in a mk11
Postby Neil » Fri Aug 08, 2008 6:32 pm
why behind the seats :?:
Neil v6
Neil
Re: v8 in a mk11
Postby Muttley » Fri Aug 08, 2008 6:43 pm
It would have to be fitted very low down or the propshaft angle would be too steep, I doubt u would have enough length unless u use a lwb van!
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Re: v8 in a mk11
Postby truckdoctor » Fri Aug 08, 2008 6:48 pm
Mid mounted ,and as low down as possible , a bit like the mk1 supervan with flared arches and massive wheels ,I drove a mk1 around London for a living in the 70;s ,getting a bit old now and just thinking about what i should of had then but couldn't afford ,but now !!!!
truckdoctor
Re: v8 in a mk11
Postby truckdoctor » Fri Aug 08, 2008 7:31 pm
Yes muttley ,you are probably correct,as i remember a long wheel base is semi high top and won't go in the garage , what about an audi fwd that uses a trans-axle ,much shorter ,lots more work though, gotta be done.
truckdoctor
Re: v8 in a mk11
Postby Muttley » Fri Aug 08, 2008 7:32 pm
To be truthful it would be a doddle, cut out all the floor between the rails, lower in your v8 and box. Line it up with the diff flange and fabricate a frame to fix it there. Then replace the floor around it creating more strength where needed. All u would then need is a very short propshaft a bit of plumbing and wiring, a radiator and voila!! :wink:
Muttley
Re: v8 in a mk11
Postby Muttley » Fri Aug 08, 2008 7:33 pm
U can get a low roof lwb I think, Fred would know :D
Muttley
Re: v8 in a mk11
Postby truckdoctor » Fri Aug 08, 2008 7:40 pm
Voila ? what's that where do you get it
truckdoctor
Re: v8 in a mk11
Postby Luke » Fri Aug 08, 2008 7:52 pm
i reckon it will go in even a swb - i actually measured it up and did some drawings etc. something ive considered for a future project :mrgreen:
and go for it - be great to see 8)
Re: v8 in a mk11
Postby Muttley » Fri Aug 08, 2008 7:54 pm
Voila! means then u wake up and find it was all a dream :wink:
Muttley
Re: v8 in a mk11
Postby truckdoctor » Fri Aug 08, 2008 8:04 pm
no, not this time :wink: just give me time
truckdoctor
Re: v8 in a mk11
Postby motorwise » Fri Aug 08, 2008 8:09 pm
Muttley wrote:Voila! means then u wake up and find it was all a dream :wink:
:lol: :lol: :lol:
http://www.motorwise.net
motorwise
Re: v8 in a mk11
Postby FredTransit » Fri Aug 08, 2008 8:19 pm
There is only two stock roof lines in the Mk1 and the Mk2, flat on the SWB and higher on the LWB. There is a High top fibreglass roof but I have a feeling that's aftermarket.
FredTransit
Mk2 Trannyist
Re: v8 in a mk11
Postby Neil » Sat Aug 09, 2008 4:59 pm
swb van will take a v8 mk 1 or 2 :wink: and you sit it upfront ,modify the bulkhead
Neil v6
Neil
Re: v8 in a mk11
Postby spitfire » Sat Aug 09, 2008 7:58 pm
One maniac car builder has putted a mid mounted Twin Turbo V8 with over 1000 HP into a Transporter so the swb should do awright :D
Ketil
Ketil
Norway
ketil.frengen@norgespost.no
2,9 Cosworth V6 1968 mod LWB Twin wheeler
viewtopic.php?f=27&t=49610
spitfire
Return to Transit Talk
