Wheel Bearing
Wheel Bearing
Postby AlanN » Thu Sep 04, 2008 8:34 am
Have been getting a bearing noise from the van, but I can't quite work out where its cominig from... Hoping its not the recently fitted diff!
I thought I would replace the bearings on all wheels in the near future, so I had a quick look on fleebay and I could only find one front bearing listed for a MK3, or am I searching for the wrong thing :oops:
Re: Wheel Bearing
Postby BigNeil » Thu Sep 04, 2008 9:14 am
have you tried a quote from your local factor as they will have the right thing or atleast be able to get the right thing for you :)
BigNeil
Re: Wheel Bearing
Postby FredTransit » Thu Sep 04, 2008 10:05 am
Yep, as BigNiel said, you should be able to get the bearings over the counter. We have Mk3 back axles and still get them easily.
FredTransit
Mk2 Trannyist
Re: Wheel Bearing
Postby bron y aur » Thu Sep 04, 2008 9:12 pm
yep, i have mk1 axles and can get them.
i started with nothing, still have most of it left
bron y aur
Return to Transit Talk
