Fitted the split charge.. eventually!
Postby darkbluevanman » Sun Nov 09, 2008 11:48 pm
Not that it took long to do, just that I'm a lazy bum!
'99 Diesel, fitted the petrol tray on the left, bought a new battery for main & old one on the left, intelligent split charge kit from the popular auction site (one that senses voltage on the main battery, you just link one batt to the other, fuse at both ends going to the little box (+ an earth)) little box looked a bit exposed, so mounted it through the bulkhead on top of the glove box (ideal, going to place 2nd fuse box there, get in through pocket on top of dash).
Worked spot on, really simple! going to fit a couple of battery meters to monitor both batts, and run some thicker cables from the 2nd batt for an inverter (not a camper!) and some extra 12v sockets too in the back.
Only reason, Ive done this is because we went to a track day and I had one of those 12v fridges running for about 2 hour after we stopped (plus, doors open so int' lights on! (sorting that with leds!))... when leaving fired no problem, but the fanbelt was screeching, so I presume it knocked it out of the battery!
Looking for 12v gadgets now ;)
darkbluevanman
Re: Fitted the split charge.. eventually!
Postby jay » Mon Nov 10, 2008 12:29 am
12 volt microwave is handy.
mk1 connect tourneo
jay
Postby Dan T » Mon Nov 10, 2008 12:32 am
jay wrote:12 volt microwave is handy.
Or an inverter :wink:
Dan T
Postby darkbluevanman » Thu Nov 13, 2008 7:47 pm
Bought an inverter.... more ebay tat!!! when it came something was loose inside, took bottom off to look (plate floating about, didn't go anywhere!), poor quality build... fire waiting to happen, daren't risk it!
darkbluevanman
Postby trigger » Sun Nov 16, 2008 6:13 pm
Did you send it back and ask for your money back?
Mk5 Transit the daddy
trigger
Return to Transit Talk
