by jay » Sat Feb 11, 2006 10:59 pm
had a bit of a problem for the past day when out and about..but it only happened when towing a trailer...the indicators would work fine when solo but as soon as a trailer electrics coupled the indicators would not work .found out the problem was nothing more than a fuse has melted inside but was not visible as the fuse was not the clear type but the old ford type that is made of hard plastic with the fuse wire at the end the fuse wire was ok but when i looked carefully inside u could see the burned bit..dunno if anyone has had this before..
mk1 connect tourneo
