Some facts about the weights as I understood them, I thought I had it all figured out as I wanted to be legal for towing as I do alot of it:
I have a Mk5 SWB 150 rated at 5,200kg GTW
I got the van on a weighbridge a while back with a full tank of fuel, a usual supply of tools and me in it, and it weighed just under 2200kg, I never have more than this in it for towing. So we can safely assume my 'job ready' kerb weight is under 2200kg.
I use a Brian James trailer which is plated at 3000kg, and weighs 750kg... it has a load capacity of 2250kg
This (I thought) left me legal as my GTW would be at the specified 5,200kg, and my B+E entitlement means that the MAM of the trailer doesn't have to be less than the unladen weight of the towing vehicle.
I got pulled over and taken to a weighbridge just a couple of miles after leaving, which was a first for me. The GTW with the landrover on the trailer come in at 4941kg... great I thought, on my way...... no
The copper then informs me that the combined weight of the MAM of the trailer (which I knew the MAM would be used not the actual weight if it's lower) and the MAM of the towing vehicle is over the GTW. I wasn't aware that the weights for the towing vehicle were the MAM weights, I thought it was actual weight.
It turns out that the MAM of my van is 3200kg, leaving only 2000kg MAM remaining for legal towing... this is quite useless for me. If I get a lightweight trailer of around ~500kg, the most I can legally tow is 1500kg weight on the back? meaning that towing the likes of large vehicles like Landrovers and Transits is impossible
In all fairness the coppers that got me were very reasonable, they took into consideration that I was simply misunderstood about the towing weights and was indeed fully licensed and made every attempt I was aware of to be legal. They didn't give me any fine or points, but had to escort me back.
This is a major blow for me, I get a fair bit of work towing Landrovers about, and now I find I can't do it legally. Is there any LEGAL way of reducing my van's GVW and keeping the 5200kg GTW? I never go over 2500kg with the van on it's own, so if I could reduce it's MAM to that whilst keeping the GTW at 5200kg I would have a towing weight of 2700kg, which would be much more manageable. Is that atall possible? I'm gutted!
