thread on all the different gearboxes
Postby Luke » Sun May 31, 2009 10:23 am
i thought it would be a good idea to have an info thread with all the differnt gearboxes fitted as standard to transits with pictures and details of what years etc. they were fitted to :D
then once it's complete we'll move it into the usefull information section :idea:
or if you just have a good picture of a gearbox not listed but ddont know what it's off post it up and somone will fill in the details :lol:
Re: thread on all the different gearboxes
Postby Luke » Sun May 31, 2009 10:25 am
i'll start :D
DOHC MT75 - fitted to 2.0 8v DOHC (I4) mk5 smiley transits 95-00
this box doesnt use an adapterplate as the earlier petrol boxes did :D
it's a 5 speed and this is the shift pattern
Postby redeemer » Sun May 31, 2009 7:42 pm
Well have went down with camera, and I relized I have 4 boxes :o
Nothing special
Here Is the Famous Mt75 5 speed gbox, all gears are sycromeshed including reverse (which is not a flat gear that goes between another two thus no reversing noise!)
there are twp variants :
Close ratio ; have some ratio differences int 1st 2nd and 3rd gears which make it ideal for towing
Wide ratio: ideal for SWB vans with not much load.
Here is my question :
This 4speed gearbox was taken out from a factroy diesel Mk2 van with the di engine(phase 2)
This one doesn't have a solid bell housing, but it is covered with a plastic cover as in here
Also this gbox have a reverse light swith because phase 2 rear lights have the reverse light :wink:
What type is this? Who knows can add info to my post no probs
Dont mind the onions :lol: I tipped the box to take the pic :lol:
This Is another 4 speed box but with a solid bell housing , and no reverse switch;
Here its when separated from bel housing and tail;(and ripped off)
And finaly another four speed gearbox , same as the two shown previously but different belhousing for adapting to the old Perkins 4108 :lol:
And here is a pic showing the difference between the 4speed box gear lever and the Mt75 one:
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby rover » Sun May 31, 2009 11:08 pm
This is the A4LD gearbox, this one on the Pinto engine, its a 4spd Automatic with lock up on 3 and 4, fitted to a few Transits between 1988 and 1992, the later box looks very similar but has an electronic solenoid rather than vacum controlled and was known as the A4LD'e', this later box was fitted on the Di Turbo models up to 2000.
rover
Postby jpv » Sun Jun 14, 2009 11:06 pm
What about 4 speed boxes with overdrive? What ratios do they have?
What about Type9 gearbox photos?
Great info! Regards!
João Vale
jpv
Postby MinorMatt » Mon Jun 15, 2009 7:07 pm
redeemer wrote:Close ratio ; have some ratio differences int 1st 2nd and 3rd gears which make it ideal for towing
Wrong way round mate ;) Wide ratio is better for higher loads, the gears are wider spaced (ie. 1st and 2nd are lower) meaning the engine wont have to try so hard to get the load moving.
Its why sports cars are fitted with close ratio gearboxes ;)
Postby redeemer » Mon Jun 15, 2009 11:05 pm
Thanks Matt :D
I read it somewhere else but , I may have turned it the other way :lol: .
Anyone know what type is called that 4speed standard box F ,J or what?
Feel free and modify my post :wink:
redeemer
Postby Luke » Mon Jul 27, 2009 10:18 am
stolen from oldskooler's mk2 progress thread :lol: .........
this is a type 9 5 speed with the propper transit stick :D
fitted to mk3 transits 1986-1989 before they introduced MT75
they are basically the same box as a car one and you can fit the transit selector to a car box - but you can see this is a genuine transit one as there is no mounting holes for the car stick :D
btw this particular one has a pinto bellhousing fitted but you can get a Di one i'll add a pic if i can find one :D
shift pattern is :arrow: Image
Postby sos recovery » Tue Jul 28, 2009 1:38 pm
wicked info geeezahs ...anyone show us a 4speed manual /pinto combo in a mk3 i need the location of the stick if poss? mines a conversion and bloody dificult to deal with lol
Nemo Mi Impune Laccesit,or as they say in Glasgow Get tae F=== ya Bassa
sos recovery
Postby oldskooler » Sat Aug 01, 2009 2:20 am
shift pattern is :arrow: Image[/quote]
that box actually still bolted up to the adaptor plate that originally was on the van, ie not directly to the pinto. in other words it had the same bellhousing as the 4 spd that came out. is that the diesel one and have the york and di have the same bolt pattern??
oldskooler
Postby Daveyboy » Sat Aug 01, 2009 3:18 pm
I can remember when I was an apprentice working for the council, mid/late eighties I guess, and I'm sure we had Di diesels with 4 speed boxes but with a switch on the gearstick for overdrive? Or did it work on 3rd too, as like a splitter between 3rd and 4th? Its all a bit vague now :lol:
Daveyboy
Postby rangie76 » Sun Oct 09, 2022 5:10 pm
There is a picture back up page of a starter motor facing rearwards on a alloy bell housing does who ever had that still have it ?
rangie76
Return to Transit Talk
