Why was there never a SWB 190 ???
Postby Luke » Fri Mar 31, 2006 8:47 pm
Anyone know why ford never built a 190 in a swb :!: why is the biggest swb limited to 150 :?
why is that :?:
:D
Postby gemini » Fri Mar 31, 2006 9:23 pm
could be something to do with the early 190's having twin wheels, cant think of anything for the newer ones though, unless its something to do with the weight of the vehicle
gemini
Postby Luke » Fri Mar 31, 2006 9:26 pm
yeah i suppose i could understand it when the twin wheelers were about but 92-00 why not :?:
i wonder if you could reshell a 190 lwb in a swb shell :?
Postby gemini » Fri Mar 31, 2006 9:30 pm
they are basically the same aren't they apart from the rear axle & springs
gemini
Postby Luke » Fri Mar 31, 2006 9:39 pm
gemini wrote:they are basically the same aren't they apart from the rear axle & springs
i think the axle is the same :?
Postby 100ps_drw_hicube » Fri Mar 31, 2006 9:56 pm
150 axle is the same as my old hicube left dhl with a wineing axle so changed it for 1 out of a rac van :) springs are the same too :) just the weight on the plate i think :? and maybe front axle is plated at a different weight :? not sure tho :?
100ps_drw_hicube
Transit Abuser!!
Postby madmark » Sat Apr 01, 2006 4:43 am
i think the 150 is useing the same parts as a 190 i should think you could have a 150 plated to a 190 if you wanted! :lol: :lol:
Return to Transit Talk
