central locking
central locking
Postby crazyscoot » Mon Apr 17, 2006 7:19 pm
Had another look at my sliding door central locking today, I cant work it out? When i lock all the doors the sliding door opens when you unlock the doors it locks!? Ive been without the actuator for polly 12 months or more now becuase the old one packed up. So, all ive done is replace it, no wiring messed with. Well the conclusion (just so i can get it working again) was to take the actuator of the ford bracket and turn the motor 180 degrees and drill and screw it directly to the sliding door. Works a treat but i still dont know why it would have, in effect reversed itself? Are the actuators the same for the front doors as they are for the sliding door?
Negative reality inversion
crazyscoot
Postby Luke » Mon Apr 17, 2006 7:29 pm
isnt it just plugged in the wrong way round?
Postby 100ps_drw_hicube » Mon Apr 17, 2006 7:33 pm
there weird thing's aint they mine every now and again does that then self fixes it self for a few weeks :? :lol: :lol: any chance of some pic's ??of what you done as i will try that on mine :idea:
100ps_drw_hicube
Transit Abuser!!
Postby crazyscoot » Mon Apr 17, 2006 7:36 pm
will only go in one way. I even pulled out 2 of the 3 pins connected and reversed them. it would then lock but not unlock There are 3 wires = 2x switch wires and 1x earth.
crazyscoot
Postby crazyscoot » Mon Apr 17, 2006 7:46 pm
as you can see i got the position wrong the first time so had to reposition it further back. Now instead of pulling the lever to lock it, it now pushes to lock. hope this will help you hicube
crazyscoot
Return to Transit Talk
