Transit who's engine came to the end of it's life at the weekend.I was wondering what does the term 80 100 and I think 120 mean?
100ps_drw_hicube wrote::lol:quite a few early mk5's swb's didnt have p.a.s and btw the only engines you will get on swb are 70ps 76ps and 85ps turbo also the 115ps dohc rac's are 150's and usually 85ps turbo's but top speed on them isnt too good due to the axle ratio
ex bt's are uaually 70ps and 120
i really should get some sleep
MarkM wrote:Oh and I rarely go to bed much before 3 am so if that was a hint that I made a cock up 'cos it is late it has nothing to do with it I just made a cock up
MarkM wrote:Loaded weight limit., the most common SWB with a high weight capabilty is the 120 though unfortunately unless it is a former RAC vehicle or all the options boxes were ticked when new it only has the 70ps engine. Most people have 80's and 100's, I had a 120 petrol followed by a 100 petrol and now 120 diesel
Engines are 70ps 76ps 100ps and upwards
SHR is used in trade ads to mean semi high roof
Hi-Top for the high roof and the vehicle often had Hi-Cube as a badge
SWB you already know
LWB is Long Wheel Base
The newer models have a MWB which of course is Medium Wheel Base
Smiley grill versions appeared at the M reg and I don't believe any didn't have PAS so you will be looking at that model onwards. Of course earlier versions did have PAS but the money available will factor in as we don't know your budget.
*edit* just seen your post in the welcome section. 3k should buy you a pretty late Transit with most if not all of the toys.
