land rover template required
Postby transittrev » Fri Feb 04, 2011 7:53 pm
hi ya guys has any body got a template for drilling land rover wellers please will pay for postage both ways cheers
transittrev
Re: land rover template required
Postby darkbluevanman » Sun Feb 06, 2011 1:02 pm
I'll try and get a few chopped out this week (4/5mm)... had promised some before but get sidetracked with beer & pizza!
darkbluevanman
Postby darkbluevanman » Wed Feb 09, 2011 11:56 pm
Will hopefully have some 2moro, should be able to post out for about 5/6/7 quid all in (weight wise), only half a dozen... so pm me if your interested :)
darkbluevanman
Postby darkbluevanman » Thu Feb 10, 2011 8:00 pm
Got 'em now... o'ring of mild steel (inner 120mm, outer 210mm) 5mm thick, 5x16mm holes for the landy PCD (could use normal bolt I suppose!) and 5x5mm pilot holes for tranny PCD, will have to be 7 quid delivered, heavier that I thought.
Six only, when they're gone, they're gone!
darkbluevanman
Postby maycontainnuts » Sun Feb 13, 2011 1:26 pm
can i have one
1983 mk2 2.4 swb
2006 mk6 transit recovery truck
2008 mk7 service van
maycontainnuts
Postby darkbluevanman » Sun Feb 13, 2011 3:21 pm
PM Me.
darkbluevanman
Postby Drizz » Sun Feb 13, 2011 7:47 pm
And me please!
Drizz
Postby maycontainnuts » Sun Feb 13, 2011 8:13 pm
you should have beer tokens by now rgds andy
1983 mk2 2.4 swb
maycontainnuts
Postby darkbluevanman » Sun Feb 13, 2011 8:50 pm
Yes, there was no need ;)
darkbluevanman
Postby G40GES » Sun Feb 13, 2011 8:54 pm
hay DBVM can you sort out similar for a six stud?
dont gettum burned just yet....
STILL THINKING :lol:
Gadge in the shed... STILLfreezing me bits off...
G40GES
Postby darkbluevanman » Mon Feb 14, 2011 7:49 pm
G40GES wrote:hay DBVM can you sort out similar for a six stud?
You hum it son, I'll play it!
darkbluevanman
Postby darkbluevanman » Mon Feb 14, 2011 7:50 pm
AND!!!! they're 8 quid delivered.....Sorry!... just cost 3 quid to post 2nd class!
couple left.
darkbluevanman
Postby G40GES » Mon Feb 14, 2011 7:52 pm
trying to get my head around a jig for cutting the centre out of a lndy wheel ETC and lining up a fresh centre section... i can get turning done by a mateb but not this sort of diameter... can you burn a 6 stud drill jig?
G40GES
Postby darkbluevanman » Mon Feb 14, 2011 9:51 pm
Could, but what are you coming off? another PCD? Centre? ??
darkbluevanman
Postby G40GES » Mon Feb 14, 2011 9:55 pm
i'd use a centre so no mater what diameter wheel or centre blank, the jig could always be used.
do you laser 'em and the computerworks it out? or are you old skool with the blue and pointer :lol: no puns intended
G40GES
Return to Transit Talk
