Sundowners 6Cyl MK2
Postby Luke » Thu Jul 28, 2005 12:27 pm
great piccs mate!! 8)
i like the dimma style fuel cap! im after a new fuel cap for mine the standard mk1 chrome one looks a bit pants!!
was it difficult to fit? are they expensive?
Postby MRspivvy » Thu Jul 28, 2005 12:49 pm
flip, thats a straight six in there! is that the back of the engine you can see poking in to the cab? I bet thats a right torque monster, swb too! lots of tail happy fun I'll be bound. I want one.
MRspivvy
Postby Sundowner » Thu Jul 28, 2005 1:22 pm
Hey luke the filler is an easy fit, took me about 20 mins
All you need to do is remove the original filler neck cut about 70mm of it put the new filler in the hole (no mods) and drill the holes for fixings, fit the old now shorter filler neck back to the tank and join the new and old fillers with a length of chemical resistant hose
As for cost this filler was $307au so their not real cheap
And yes MRpivvy thats an inline 6 in there its a 250ci (4.1l) ford crossflow
Factory rated at 85kw @ 3900rpm and 200ft/lb @ 1800rpm their an extreamly strong and reliable engine and also quite long the rear of the engine is almost inline with the dash and the gear stick sits beside the handbrake lever
Sundowner
re van
Postby express post » Fri Jul 29, 2005 12:24 pm
i have stipped my 1978 (see pics 1978 transit) have all the parts but no shell got all the doors ,drive train,wheels
if you want any thing email me
express post
Postby Valsheda » Fri Jul 29, 2005 6:34 pm
WOW MATE WHY :shock:
Valsheda
Top Tourneo Owner
Postby MrMPuk » Fri Jul 29, 2005 6:43 pm
Like he says in the other post, cause it's rotten.
Postby Valsheda » Fri Jul 29, 2005 6:48 pm
THANKS FOR POINTING THAT OUT , THOUGHT HE HAD A MOMENT OF MADNESS
Valsheda
Top Tourneo Owner
Postby Sundowner » Sun Jul 31, 2005 5:24 am
Started on the interior with a dash revamp
Sundowner
Postby Sundowner » Tue Aug 02, 2005 9:35 am
More dash pics
Its not quite finished yet, still need to get a grey vinyl cover made up for the metal part of the dash and a "TRANSIT" insignia made to go on the red panel
Sundowner
Postby FredTransit » Tue Aug 02, 2005 10:07 am
She's coming on. I wouldn't have thought about putting the radio where you did. You might want to just replace that warning light cover (under the sppeedo). When the light hits it it looks lit up, and you will be constantly wondering if you need brake fluid or something. Worse still, there is a light on there that not even I know what it's for! Had a small electirical fault once, and rang the mechanic, he didn't know either!
What's that in your glove box, is it AC?
FredTransit
Mk2 Trannyist
Postby Sundowner » Tue Aug 02, 2005 10:48 am
Cheers fred
The lights under the speedo dont do anything and the clear peice was painted black before i cleaned it up, theres no lights in the loom for it
The radio was there when i got the van and will be removed and blanked off and yes thats the AC in the glove box :D
Sundowner
Postby FredTransit » Tue Aug 02, 2005 11:03 am
Sundowner wrote:Cheers fred
No sockets on the loom for warning lights!? :shock: I have checked the owner's manual (for the phase2, so don't know if this applies to the phase1) and the warning lights are L-R, low vacuum (servo fault), dual brake warning (low fluid), and cold start (diesels only). The last one I didn't know about cos we only have 1 factory diesel, and it now has a late Di with no glow plugs.
FredTransit
Mk2 Trannyist
Postby Sundowner » Tue Aug 02, 2005 11:32 am
Nup only warning lights i have are for low oil press and low charge
Sundowner
Postby FredTransit » Tue Aug 02, 2005 11:42 am
If I were you I would look in to this, the lights are there for a reason and you should have them as there is a panel there for them. After all, you would want to know if you suddenly didn't have any brake fluid, wouldn't you?
FredTransit
Mk2 Trannyist
Postby Sundowner » Tue Aug 02, 2005 12:11 pm
Australian design rules (ADR's) passed the need for a fluid level warning light on some late 70 early 80 vehicles
Sundowner
