bondy wrote:ovlov wrote::shock: I'm building a garage/workshop can anyone tell me if I can do any of the wiring myself or do I now have to pay a sparky to do every thing I've done a fair bit over the years but dont have any qualifications etc
I've read through the building regs but never read anything that contradicts it self so much
when you come to do the wiring, you also have to make sure the rest of the house bonding and earthing is up to scratch. there is nothing stopping anyone doing their own wiring, but as crazyscoot said. you can get a spark round to pass it off. i have the same problem at the mo. ive spoke to a couple of sparks about doing the testing and certification, and they all say they're not interested. the best route is through the local building control office. it depends how fussy they are though. if they want to be real twats, there are other building regs that are relevant. ie where you can and cant drill holes in joists. my wife's mums neighbour in Bristol did his own wiring for a loft conversion. he drilled through the joists and fitted all the cables. build control man made him change the joists which he had only just fitted 2 weeks earlier.
absolute freakin nightmare
Your spot on Bondy
Ive always found that the building inspector is either your best mate or your worst nightmare
Experience says that if the inspector says to do something then dont argue that its ridiculous and start to condescend him, just do it with a smile. If you start to argue the toss they WILL dig deeper and they Will find something else
What a lot of sparks do if something like an extension is being built is to run a new sub-main in from the incoming service. Doing this allows you to certify what you have done but it doesn't bring the rest of the property into the test and inspect. I will always tell the customer this so that they are fully aware that if i extend the existing wiring out to the extension then it will bring the whole house into the equation and it can open a can of worms they may not wont to know about. I will always upgrade the earthing as a matter of coarse.
