by neutronixx » Tue Mar 18, 2014 8:33 pm
Hey Anthony,
The van looks wicked! I'm thinking about doing the front grill debadging on my van, ive got a donar grill to do it on. When you cut out the plastic section (that the badge sticks to) does it makes the 2 cross beams really weak and floppy? The plastic badge bit links the two beams together so would make them much stronger. Did you have to reinforce these beams at all?? or once its fitted back on the van is it ok?
Also do you have any tips? I was thinking glueing a plastic plate behind the hole where the cutaway plastic was and then building up to the surface with filler.
Dave
