mk7 transit freshin up.
Re: mk7 transit freshin up.
Postby neutronixx » Tue Mar 18, 2014 8:33 pm
Hey Anthony,
The van looks wicked! I'm thinking about doing the front grill debadging on my van, ive got a donar grill to do it on. When you cut out the plastic section (that the badge sticks to) does it makes the 2 cross beams really weak and floppy? The plastic badge bit links the two beams together so would make them much stronger. Did you have to reinforce these beams at all?? or once its fitted back on the van is it ok?
Also do you have any tips? I was thinking glueing a plastic plate behind the hole where the cutaway plastic was and then building up to the surface with filler.
Cheers
Dave
neutronixx
Postby transitandy » Fri Mar 21, 2014 1:47 am
Very nice m8y :)
Postby anthonyreid » Tue Mar 25, 2014 8:30 pm
Thanks guys.
No it doesn't make it too flimsy, I used bits of plastic bumper and stapled and plastic welded it in place then used fibre glass at back as an extra reinforcement.
It really isn't rocket science so u will manage.
anthonyreid
Postby chriswalker1 » Fri Jun 27, 2014 3:57 pm
Nice job,
Did you have to buy two sets of skirts?
Are they standard sports alloys?
chriswalker1
Postby reidy386 » Sat Jul 12, 2014 7:08 pm
Hi, yes two sets of skirts, but couldn't find two sets the exact same, they were very slightly different.
No just aftermarket alloys,
reidy386
Postby reidy386 » Sat Jul 26, 2014 4:29 pm
Thought a would treat Van to a gd wash tday.
reidy386
Postby reidy386 » Sun Jul 27, 2014 8:56 pm
reidy386
Postby chriswalker1 » Wed Aug 27, 2014 9:40 pm
How did you spray the inside of the lights and what colour did you use?
chriswalker1
Postby reidy386 » Thu Sep 04, 2014 9:19 pm
Just heat up the sense ins use a sharp kinds screwdriver and than paint with mat black.
reidy386
Postby Manwithvan » Sun Sep 07, 2014 3:52 pm
Loving the van. Great job mate.
Manwithvan
Postby reidy386 » Mon Sep 08, 2014 10:08 pm
Thanks a lot.
reidy386
Postby glenandemm » Tue Sep 16, 2014 9:57 pm
hi pal really nice looking van, i knowyou modded the side skirts to fit your longer wheel base but generally are they bonded to the sills or screwed in underneath etc, just asking as im toying about with fitting a set on my mk6 after i got rid of the rust to neaten them up!!
glenandemm
Postby reidy386 » Wed Sep 24, 2014 6:55 am
They are bonded on, I had to screw them on while sealer hardened then filled holes where screws were then painted on Van. Made couple brackets for bit extra strength underneath, also Did another one and filled back with expanding foam, this helped strengthen them too
reidy386
Postby We build » Fri Feb 13, 2015 3:10 am
Hi mate new to the forum I have the same van as yours in silver. Just wondered what wheels were hours as mine is a t350 mwb 140 and what load rating size wheels they are cheers tom
We build
Postby theshagger » Thu Jan 03, 2019 11:51 pm
She looks the bollocks mate where did you get the tailpipes look neat
theshagger
