maxlees van
maxlees van
Postby maxlee » Tue Mar 14, 2006 11:38 am
right at last got 5 mins so i can put some pics up
these are my befor i have tuched it pics :lol: the roof rack you can see is a big pain in the ass it leaking over the years has help feed the rust monsta :cry:
yestoday me and a mate ripped out every thing inside in order to get the 10+ years of dirt mud and dust out of the old thing
next on the list is get rid of them stickers and a bit more cleaning
maxlee
Postby maxlee » Tue Mar 14, 2006 11:49 am
under the front carpet
after removing 4 mounds like this from just the front
got about 8stone of dirt from the van so far :roll: dam them bilders a :lol:
new alarm fitted and working dont no if it nocks the insurance down but its far better then any cat alarm
by the end of the night
need to lurn to weld then i gess
still well cheffed with the van tho no probelms as yot running wise and it dosen't leak oil any were on the hard standing
:shock:
also found 8 seat belts fitted in the back :?:
must have had bench seats at some time in its life
maxlee
Postby Luke » Thu Mar 16, 2006 12:31 am
maxlee wrote:need to lurn to weld then i gess
mate if thats all you find you've done well!!! :D and its a nice easy bit to learn on too!!! :D
looks a decent solid van :D - do yourself a favour and while the linings are out waxoil the back especially the rear arches from the inside!!! in a few years you will be glad you did!!! :D
Postby maxlee » Fri Mar 17, 2006 12:02 am
after i have good all the crap from inside the arches out i will do that for sure :D
maxlee
Postby maxlee » Tue Apr 18, 2006 7:01 pm
got a bit hacked off with having crap sounding tunes in the van so made some changes yes2day :D
6x9's a litte bit better then the ford speakers
new head unit
i now have bass again :D
also fitted a cone filter it was laying around and my standed one was black so i thought "why not" :wink:
maxlee
Postby FredTransit » Tue Apr 18, 2006 7:05 pm
I like your alarm system, can he weld?
FredTransit
Mk2 Trannyist
Postby maxlee » Wed Apr 19, 2006 12:39 am
fur coat might be a problem when welding i no waring a fleace isn't clever :oops:
maxlee
Postby MarkM » Wed Apr 19, 2006 8:23 pm
Did you have to do much cutting to fit the 6x9's as I have a brand new set in a box I was going to fit in a plywood window on a previous transit but scrapped the van before I ever did anything and thought I wouldn't ever be able to use the speakers...this gives me some hope as the Ford units start to flap after 19 on the volume.
MarkM
Postby crazyscoot » Wed Apr 19, 2006 8:38 pm
The 6x9 go in Mark but you do have to cut a bit of the door out. It was a bit tricky to get a neat cut tho. If i remember rightly i could only get three fixings but this didn't seem to bother them. 6x9 three ways mine are, the three ways do stick out a bit more but the panel does go on with a slight bend. The window winder very slightly catches the door when your at 10 oclock to 12 oclock.
Negative reality inversion
crazyscoot
Postby MarkM » Wed Apr 19, 2006 8:50 pm
Ok well I will have to find the speakers and have a look, I really can't remember if they are 3 way or 2 way or a 3 way with a combined mid and tweeter as they were bought about 4-5 years ago...one of those "ooh those are cheap I will buy them for later on" sort of purchases.
Many years ago I put some speakers in the doors of my Chevette, did it all a bit quick and did the drivers door first cutting the door panel and it all went in fine so I simply measured the same amount forward of the passenger door handle and cut it out only to find that the passenger door handle is not symetrical to the drivers one so I had to cut the inner door panel to get the speaker to fit :oops:
MarkM
Postby crazyscoot » Wed Apr 19, 2006 9:14 pm
har har.....dont you just love it :D one other thing i did while the door card was off was to stick .....wait for it! sticky back flash band! Its far cheaper than buying sound deadening pads from the local car audio shop and i reckon its just as good. Basically covered the whole door with it! :D in fact i didn't stop there i got so carried away i did the whole bloody cab :D roof included. The difference is huge because the panels dont resonate when your on the move, which is a big contribution to the noisy van syndrome and the other big difference is when you shut the door it shuts with a thud rather than a hollow clang That was in my last tranny (god bless her soul :lol: ) i haven't done it in this one but those sunny days are just around the corner :D
crazyscoot
Postby MarkM » Wed Apr 19, 2006 9:22 pm
Want to link me to that band stuff please...sounds interesting. I have a panel somewhere on my Transit that booms when I reach a set speed and once it has boomed the once it doesn't do it again until I have stopped, done what I have to do and then drive off again. I am thinking it is the rear roof panel to be honest as the previous ouwner had roof bars and heavy ladders on it and was far from careful putting them back on each day so the roof is a little curved at the very back (could be an optical illusion though) but then how often does anyone see or get to see the roof of a Transit ;)
MarkM
Postby Transitwalla » Wed Apr 19, 2006 9:24 pm
Just the same with my van when I bought it . . loads of sound deadening under the front carpet, under the load area boards, in the sills, in the doors and dust and light grit under the dash . . them builders know how to make a mess :)
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Postby crazyscoot » Wed Apr 19, 2006 9:39 pm
MarkM wrote:Want to link me to that band stuff please...sounds interesting. I have a panel somewhere on my Transit that booms when I reach a set speed and once it has boomed the once it doesn't do it again until I have stopped, done what I have to do and then drive off again. I am thinking it is the rear roof panel to be honest as the previous ouwner had roof bars and heavy ladders on it and was far from careful putting them back on each day so the roof is a little curved at the very back (could be an optical illusion though) but then how often does anyone see or get to see the roof of a Transit ;)
Flash band comes on a roll (about 10 meters i think) £15 any builders merchants sell it. Two things to remember wipe the surfaces down first otherwise it wont stick. cutt the flashing to the size's you need then heat each piece up before you stick it on (carefull its sticks like s##t to a blanket)
As regards to the boom your getting, get in the back of the van and push the roof up if you see it seperate from the strengthening cross members then thats where you boom comes from. you can cover the roof panels in nthe back no probs. Only thing that i used to think might be dodgy was the fact that its basicaly sticky tar, so in a fire it would look like an oil refinery has gone up! Thick black smoke, but then again if it catches fire its all over anyway!
crazyscoot
Postby MarkM » Wed Apr 19, 2006 9:51 pm
Ah ok Flash Band...I just twigged what it is...yes I can get some of that easy.
I will check the rear roof over the weekend and see if it is that, does sound to be likely, but it is difficult to trace noises when you are the only one in the van...I have engine noise coming from I think the passenger side bulkhead to the engine but that is very likely a rubber grommet out of position just as the one my older van had with the clutch cable grommet as I happened to check it out and sure enough it was loose, a few minutes with a screwdriver and wow the noise difference was amazing and I had put up with it for months. I am about to switch the complete dash so access to all the bulkhead grommets will be easy, I might even add some sound deadening material at the same time, though the fire aspect of the flash band in an area that gets warm and with so much electrical cable doesn't sound to be that good an idea so I think I will go the expensive route for that area.
MarkM
