my old hi-cube
my old hi-cube
Postby jonnyshag » Fri Mar 24, 2006 10:04 am
this is a list of stuff i did to it:
paint work obviously , the spotlights on top with sidelights and marker lights in each corner , 4x yellow lamps on bottom front, clear indectiors , partistioned off with a bed , blacked out windows , pug 306 seats , dump valve , turbo gauge , rear beacons , sky light in the sleeper and all was carpeted , gold step and carpet lined , air horns , musical air horns , turbo running at 12psi , gold clocks , turbo diesel graphic on both sides , window deflecors
jonnyshag
Postby 100ps_drw_hicube » Fri Mar 24, 2006 3:47 pm
thats a beast that van 8) 8) 8) i nearly bought one similar before i got mine it was identical apart from the red stripe :? :shock:
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sun Apr 02, 2006 12:39 pm
just made a list of all the mods which i did to my van
jonnyshag
