RT's LWB semi-high Mk6 (Low-roof if in Aus apparently)
Postby MrMPuk » Thu Jul 13, 2006 6:24 pm
Postby rt » Fri Jul 14, 2006 12:24 am
thanks for doing that mrmpuk
rt
Postby Luke » Fri Jul 14, 2006 12:20 pm
Looks well mate 8)
looks good lowered
Postby nitroman » Sat Jul 15, 2006 10:37 am
thanx for ideas on lowering mine
nitroman
Postby rt » Sun Jul 16, 2006 9:51 am
no problems nitroman if you want i can send you the front spring specs and you can have them duplicated just check and make sure that fwd and rwd use the same front end
rt
Postby transitgeoff » Sun Jul 16, 2006 5:53 pm
whats the point of lowering that :roll:
transitgeoff
Postby rt » Mon Jul 17, 2006 8:54 am
not sure what you mean (lowering that ?)
rt
Postby MrMPuk » Mon Jul 17, 2006 10:45 am
I think what Geoff is trying to say is that all you have done is make it look like she is over weight, maybe if it was running some fat wheels with low profile tyres but it does look over weight.
Postby rt » Mon Jul 17, 2006 12:19 pm
yeh i know it does look a bit like its got 5 ton in the back,but the wheels are getting close and with them, front bar etc done im confident it will look the goods
rt
Postby MrMPuk » Mon Jul 17, 2006 12:21 pm
I agree when it's done it will look the nuts.
