Buying advice for my next van!
Postby brookscd » Fri Aug 02, 2013 7:31 pm
Hello,
I am looking to purchase a secondhand SWB van, there is a wealth of information on here about the Transit however I am struggling to find any information relating to the reliability, common faults and things to look for, for the Renalt Master, Iveco Daily or the Citroen Relay (Fiat & Pergoet) can anyone please suggest where I could find this information or give me any advice.
I did read some where that the Citroen uses the Ford engine with a Fiat gear box, is this right, I would then assume that the issues raised on this forum such as the Fuel pup would be relevant to the Citroen.
Also Having trawled through all the information on here one major concern regarding the Transit is the fuel pump issue, is this specific to the MK6 or MK7 or both!
I am hoping to have a budget of around 5000 for the van for social use not too much hard work, I think the best option is probabily a 2.0 FWD however would like to look at what the others have to offer before going ahead.
Thank You in advance sorry for such a long post with so many questions!!
Chris
brookscd
Re: Buying advice for my next van!
Postby brookscd » Sun Aug 04, 2013 10:10 pm
Accidently found some very useful information in Wikipedia relating to the engines used in the above vans, always the way been looking around for a few days an then by accident...there it was!!
I would appreciate any information, guidence on the fuel pump issue please!
Chris
brookscd
Postby Altransit » Sun Aug 04, 2013 10:23 pm
What have you heard about the fuel pump :?:
TDDi & TDCi engines, which have completely different fuel systems, are both used in the Mk6, TDCi only in the Mk7, so which are you looking at :?:
Postby brookscd » Mon Aug 05, 2013 5:20 pm
Thank you for your reply Altransit.
I seemed looking through the forum that the fuel pump was a common thing to go wrong, read (although cant remember what thread) that they seemed to go very often as little as three years or 50,000 miles.
I wondered if it was an issue that was specific to a particular engine (I wasn't aware of the two engines in MK6)
I am probably looking at a MK6 for my budget of around £5,000
Thanks again
Chris
brookscd
Postby fedup2 » Mon Aug 05, 2013 6:40 pm
At 5 grand you want to be looking at mk7's.
Launch x431 owner ;)
fedup2
Postby brookscd » Mon Aug 05, 2013 8:31 pm
fedup2 wrote:At 5 grand you want to be looking at mk7's.
I've seen on here an advantage of the TDCI being a better engine; better MPG etc
I had thought perhaps a lower mileage, FSH , 'clean' MK6 would be better considering the budget than an average MK7
brookscd
Postby bigjohnthomas » Mon Aug 05, 2013 8:55 pm
Your livin in the past dude mk6 = rusty old tramps van :lol:
bigjohnthomas
Postby fedup2 » Mon Aug 05, 2013 9:55 pm
You came for advice,you got mine...
All the mk7's vary on mpg the bigger the ps the better they are as a rule.Go and drive both.
Finding a good van is key,it aint easy if you have high standards.............
Ultimatly its your choice.............
If you
fedup2
Postby stevo » Tue Aug 06, 2013 5:43 pm
bigjohnthomas wrote:Your livin in the past dude mk6 = rusty old tramps van :lol:
Mk7 = rusty new tramps van :lol:
Still plenty of tidy mk6's, better looking van too
Formely ibanez2005
2003 100 T260 TDDi swb
stevo
Postby brookscd » Tue Aug 06, 2013 6:15 pm
Thank you fedup2
I wasn't aware of that will look for hopefully a 130 or 140
Thanks again
Chris
brookscd
Return to Buyers Guide
