MK2 advice
MK2 advice
Postby Knulen » Mon Feb 27, 2023 10:45 pm
I'm looking for some advice, I've found a Ford Transit MK2 (1980) which I'm thinking of buying. It has a 2.0 OHC 87HP engine. What are the weak spots of this car? What do I need to look out for when buying a MK2. I guess there are a lot of places where rust can occur or some other problematic issues or expensive parts.
Knulen
Re: MK2 advice
Postby dumper » Mon Feb 27, 2023 11:25 pm
Rust is the main thing all the usual places if body ok just general service items even if it has a good recent service history I’d be giving it a full service cambelt water pump do the valve clearance I would change the oil spray bar for the camshaft hopefully parts are not to hard to find .
Re: MK2 advice
Postby Knulen » Sun Mar 05, 2023 10:48 pm
What are the usual places for rust on a MK2?
And how easy/difficult are parts to be found in the Netherlands?
Knulen
Re: MK2 advice
Postby bortaf » Mon Mar 06, 2023 2:13 am
rear arches, under the windscreen, door steps, rear valence, cab floor/inner arch, top rail where the outer wing joins the inner but TBH by now everywhere is suspect, chassis (esp spring hangers) , radiator support, bonnet hinge mounts ect
Current fleet
Mk7 transit ambulance
Mk1 tourneo connect
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Fusion 1.4TDCi
bortaf
Return to Buyers Guide
