MK5
MK5
Postby Philb » Tue Jan 18, 2011 10:32 am
Hello, I've been looking at Ford Transit's in truth mainly because I understand what a Transit is and there seem to be a great deal around within my budget; I only need something to transport my motocrosser around and so don't really want to spend thousands.
Anyway - seems the MK5 will be the likely choice in 2.5D non-turbo version. I know it will be slow but mechanically any horrors or obvious things to check - beyond it has oil and water?? Some are ex-BT and I did read something here about an odd engine spec (or components within?) - is that something to be mindful of or the issue raised a one off?
Thanks.
Philb
Re: MK5
Postby ake » Sat Jan 22, 2011 12:06 pm
BT vans had the same engine as all the other Di transits, EX BT are a good source as they are well looked after, however any EX BT MK5 will now have had several owners since BT, remember the newest MK5 is now 11 years old
Return to Buyers Guide
