about to buy a mk 5..with EPIC....! ...?
Re: about to buy a mk 5..with EPIC....! ...?
Postby slogger » Mon Jan 25, 2010 12:10 am
Not thread hijacking ( or i am ) but say the epic failed , what is the bosch option ie mechanical pump and keep the turbo is there such an option
slogger
Postby trigger » Mon Jan 25, 2010 12:15 am
Convert to a Bosch 145 or 146 mechanical pump, you still keep the turbo, you will need a throttle cable to replace the electronic one, you won't need the ECU anymore
Mk5 Transit the daddy
trigger
Postby hilliebilly » Tue Apr 05, 2011 9:51 pm
do we need to change the injectors
as mine are pencil type ones
hilliebilly
Postby Altransit » Tue Apr 05, 2011 9:57 pm
psv-hgv-flt wrote:
hilliebilly wrote:WHICH BOSCH PUMP AND WILL I HAVE TO CHANGE INJECTORS
yes, change injectors to 100ps ones. (look hear) http://www.uniteddiesel.co.uk/stanadyne ... ectors.php brown spot.
look hear this may help. viewtopic.php?f=4&t=66106&hilit=epic+to+bosch+686
:wink: :)
:wink:
Postby hilliebilly » Wed Apr 06, 2011 6:31 pm
are the 145 pump of a turbo or di
hilliebilly
Postby MrMPuk » Wed Apr 06, 2011 6:42 pm
hilliebilly wrote:are the 145 pump of a turbo or di
Di, take a look around as there's plenty of info on this conversion.
Postby hilliebilly » Wed Apr 06, 2011 8:51 pm
been offerd a 145 or 146 pump on a 75bhp bannana engine would this work with brown dot injectors as mine is turboed
hilliebilly
Postby MrMPuk » Wed Apr 06, 2011 9:00 pm
hilliebilly wrote:been offerd a 145 or 146 pump on a 75bhp bannana engine would this work with brown dot injectors as mine is turboed
145/146 pump with Turbo injectors is what you need as I said.
Postby hilliebilly » Wed Apr 06, 2011 10:09 pm
thanks i think iam getting somewhere now thanks :D
hilliebilly
Postby MrMPuk » Wed Apr 06, 2011 10:11 pm
hilliebilly wrote:thanks i think iam getting somewhere now thanks :D
Really? :?
Postby hilliebilly » Thu Apr 07, 2011 6:01 pm
nope :D
hilliebilly
Return to Buyers Guide
