mb4ever wrote:(ROG) wrote:TIMO wrote:Nice one, you can drag 2250kilo behind that , even if the van is fully loaded upto 3500 kilo
That should read - IF the van is fully loaded to 3500
Towing weight is not the GTW minus the GVW unless the van is fully laden
If the towing weight isn't Gross Train Weight minus the Gross Vehicle Weight
then how do you work out GTW please ROG?
Cheers,
GTW means the ACTUAL weight of both vehicle and trailer when placed on a weighbridge
WEIGHBRIDGE -
Vehicle weighed on its own must not exceed GVW
Trailer weighed on its own must not exceed MAM
Vehicle and trailer weighed together must not exceed GTW
The only towing weight restriction would be if a manufacturer had placed a maximum towing capacity for the vehicle and that is not usually the case for commercial vans
