Hi guys,
Just a couple of quick questions if you dont mind, should be easy enough to answer. I have been browsing the forum, and come across a few remarks about Mk6's that i hope you can clarify.
The whole loom cover recall? what was the recall for? something about cutting the loom and all the doors opening? should i be looking for any kind of modification when im looking at Mk6's?
Any other recall probs on these?
Also, fuel pumps, whats the problems with these pumps? are they expensive? and is there any warning signs that the pump may be on its last legs when im test driving?
Any other main/common faults with the Mk6's i should be on the lookout for?
Hope you guys can help..
Cheers,
Matt
