Which Transit, VH or VG
Postby Chucaro » Sat Oct 29, 2016 4:25 am
Hello you all,
I am considering purchasing a LWB high roof van to converting it to a campervan.
I have very little experience with them apart of driving a 19701 V4 LWB service van when I used to work a maintenance fitter. (she was bad indeed!!)
I live in Tasmania so problems of rust are not as bad as there are in Europe.
My budget it is limited to $12000 (Australian dollars) which can allow me to buy a VH 2003 2.4 turbo diesel with about 250000 km or a VJ with the same engine with little more money.
Which it is the best transmission (reliability)? I am happy to drive manual if it is the best.
Are there any difference between the vans and bus regarding handling? I guess that an ex bus looks attractive because the saving on windows and perhaps they are look after better than a cargo van.
Your inputs are appreciated. :)
Cheers
Chucaro
Re: Which Transit, VH or VG
Postby Punto443 » Sat Oct 29, 2016 7:14 am
So a vh is a mk6? , and I take it a vj is a mk7?
Firstly, the asm (auto shifting manual) gearbox never gets great reviews from what I've heard, but there's probably more of them over there.
I've had both mk6&7 and not really had any bother with them. The mk7 needs to have been looked after, look for genuine filters and device history. It should run spot on.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Chucaro » Sat Oct 29, 2016 7:32 am
Thank you for your reply
VH it is from 2000 ( http://www.carsales.com.au/private/deta ... 277/?Cr=17 )
VJ from 2005 ( http://www.carsales.com.au/private/deta ... 5934/?Cr=3 )
In 2006 also we have the VM with the same 2.4 turbo diesel but with different front shape ( http://www.carsales.com.au/private/deta ... 297/?Cr=18 )
In 2010 we have the VM 2.2 turbo diesel engine
Is the 2.2 engine much better that the 2.4 or both are Ok?
Cheers
Chucaro
Postby Punto443 » Sat Oct 29, 2016 7:38 am
So the vh and vj are very similar, I presume the main differences will be abs/electronic speedos etc ( forgive the unfamiliarity with Tasmanian model specs) :)
More or less the same vehicle if the same as uk specs
The vm (mk7) is a very different beast. Most would say that the 2.2 is less reliable than the 2.0fwd or 2.4rwd vh & vj
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby blue estate » Sat Oct 29, 2016 7:41 am
Chucaro wrote:Thank you for your reply
Cheers
either the 2000 one or the 2008 one as they're both manual
No the 2.2 is a worse engine suffering from holed pistons and failed pumps
the 2 I suggested both have the same engine but different fuel delivery systems
blue estate
Postby Chucaro » Sat Oct 29, 2016 7:53 am
Thank you guys for the inputs, so the 2.4 manual will be the option.
This is what I am considering as a better option than a cargo van. Have to find out how high it is inside, I am 1.850 high.
http://www.carsales.com.au/dealer/detai ... 630/?Cr=11
Cheers
Chucaro
Postby chris72a » Sat Oct 29, 2016 8:02 am
Theres a few going through pickles auctions 10200 fixed price ex postal vans, might be worth a look. One of the guys from WA has just bought one.
Cheers
Chris.
chris72a
Postby ned » Sat Oct 29, 2016 8:05 am
There's a few knocks on the passenger side, most are easy to fix but the on top left at the roof may be fiddly.
All in all it looks good and clean plus you could sell what you don't need I.e seats, big yellow handles (they go for good money over here) etc
Not sure what the exchange rate is from aus dollars to pound. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Chucaro » Sat Oct 29, 2016 8:08 am
One British Pound = A$ 1.60
Chucaro
Postby blue estate » Sat Oct 29, 2016 8:09 am
Chucaro wrote:Thank you guys for the inputs, so the 2.4 manual will be the option.
Cheers
That isn't manual look at the picture with the radio in the gear buttons are above it :wink:
blue estate
Postby Chucaro » Sat Oct 29, 2016 8:12 am
Sorry that I have expressed myself wrong, I just put it as an example of the model that I considering thinking that a community bus will be looked after better that a cargo van.
Chucaro
Postby ned » Sat Oct 29, 2016 8:14 am
So if I have worked this out correctly 12.000 dollars is about 7.500 pound. Its too early for maths :lol: N
ned
Postby blue estate » Sat Oct 29, 2016 8:15 am
Chucaro wrote:Sorry that I have expressed myself wrong, I just put it as an example of the model that I considering thinking that a community bus will be looked after better that a cargo van.
I wasn't getting at you the ad says manual
as for you high get a high top and you'll stand up in it ok
blue estate
Postby blue estate » Sat Oct 29, 2016 8:16 am
nedforceone wrote:So if I have worked this out correctly 12.000 dollars is about 7.500 pound. Its too early for maths :lol: N
you'll get a nice mk7 for that here ned :shock:
blue estate
Postby Chucaro » Sat Oct 29, 2016 8:18 am
Thank you guys again.
It is interesting the comment about problems with the 2.2 engine, it is the same as the Land Rover 110 in which they do not have that problems here.
Chucaro
Return to Buyers Guide
