Pictures of all wheel bases and roof heights
Postby Guy88 » Fri Dec 07, 2007 9:44 pm
I am not going to put pics with all of them as some would be the same
MK1 & MK2 SWB low roof
MK1 & MK2 LWB Semi high
Note the extra overhang behind the rear wheels most were twin wheel
MK3 SWB low roof
MK3 SWB Semi high
MK3 LWB Semi high
Note the extra overhang behind rear wheels Most were twin wheel
MK4 & MK5 SWB Low roof
MK4 & MK5 SWB Semi high
MK4 & MK5 SWB High roof
Very Rare combination
MK5 LWB low roof
Note the extra 4' between side loader and rear wheel
MK4 & MK5 LWB semi high
MK4 & MK5 LWB High roof
MK4 & MK5 extended frame Semi high
Also known as a Long cube. Note extra panel in middle and the extra overhang behind rear wheels
MK4 & MK5 Extended frame High roof
Also known as a Hi Cube. Note the extra panel in middle and extra overhang behind rear wheels
MK6 & MK7 SWB low roof
MK6 & MK7 SWB Semi high
MK6 & MK7 MWB Low roof
Note slightly wider panel between bottom of Side loading door and rear arch
MK6 & MK7 MWB Semi high
MK6 & MK7 MWB High roof
MK6 & MK7 LWB semi high
Note even wider panel between bottom of Side loading door and rear arch
MK6 & MK7 LWB high roof
MK6 & MK7 Extended frame Semi high
Note Wide panel between bottom of side loader and rear arch and also the extra overhand behind rear wheels
THIS IS ONLY AVALIABLE IN MINIBUS FORM
MK6 & MK7 Extended frame high roof
Also known as a JUMBO
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: A list of all wheel bases and roof heights
Postby ghasp! » Tue Jan 29, 2008 8:37 pm
I'm new to the site so sorry if it's listed elsewhere, but is the a list of wheelbases in inches or mm? Does the track width stay the same on all models?
ghasp!
Postby MrMPuk » Wed Jan 30, 2008 7:10 am
ghasp! wrote:I'm new to the site so sorry if it's listed elsewhere, but is the a list of wheelbases in inches or mm? Does the track width stay the same on all models?
What sort of year are we talking?
Postby ghasp! » Wed Jan 30, 2008 9:48 am
Not too worried about the year, but the wheelbase is important. I'm hoping to do a 3 axle conversion, so either something around 2700mm to tack on a trailing axle or approx 3500mm to fit in a drive through axle at the 2700mm position.
ghasp!
Postby 100 T280 » Sun Mar 09, 2008 1:13 am
Mk7 only (Mk6 MWB was medium or high roof only) :mrgreen:
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby markyb01 » Thu Sep 24, 2009 3:25 am
Hi,
Picked that thread up for what it advertised in the subject....
So where on there were the wheel bases and roof heights? Did I miss a trick, as all I had were photos?!
MK6 LWB Hi roof Crew Cab, 2.4 durotorque.
Doesn't use oil or water, a little belter, could do with being quicker up long hills!
Only 'mod' is lockers & 'over racking', utilising the roof space for load carrying of plasterboard, or surf boards!
markyb01
Postby MrMPuk » Thu Sep 24, 2009 10:29 am
markyb01 wrote:Hi,
Probably poorly worded, wheel bases as in SWB, MWB, LWB and roof heights as in low, medium and high not dimensions I'm affraid.
What year are you after?
Re: Pictures of all wheel bases and roof heights
Postby puckoon » Sat May 08, 2010 7:03 pm
hi there looking at the pic of the mk5 hightop (the silver one) can this model be fitted with a roof rack, in the pic it looks like it has the extended legs for it? someone told me this sort of van cant have roof racks, is this true? cheers alan and has anyone got a pic as an example.
puckoon
Return to Buyers Guide
