transit jumbo how good
Postby dumper » Mon Mar 09, 2009 8:43 pm
Hi all i am looking to buy a 2005 transit jumbo 135 6 speed 170.000 mls on the clock it has no history what do i need to look for before buying it my last camper was a mk5 100l they go on fore ever. thanks
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: transit jumbo how good
Postby martynx » Mon Mar 09, 2009 9:55 pm
Theres no run forever reputation on these as far as i know :|
Make sure it runs absolutely perfectly. instant start , quiet, pulls strong, smoke free etc... drive a few before this one to make sure ....check to see if its had bits replaced on the the engine.. no history often means patchy history thrown away so question the owner hard
Get someone who knows Ford TDCI's to check it out ...
Like with many common rail engines - injectors are £1000 a set & can cause further damage if they fail..
There's a member on here that said dont touch 135's (from a reliability point of view.) I think it was transitgeoff, i would write to him directly just to be sure.. he is a breaker so will have a good idea of what fails on them
martynx
Postby coconut » Tue Mar 10, 2009 1:20 am
That mileage and no history, i'd be walking away quite quickly :!:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby martynx » Tue Mar 10, 2009 10:17 am
I read somewhere that TDCI injectors need "attention" every 100-120k, is there any truth in that Coconut ? i am looking for a mondeo diesel at the mo & the amount on ebay with supposedly terminal engine problems was shocking... all between 1 & 200 k recorded miles
martynx
Postby coconut » Tue Mar 10, 2009 8:19 pm
I wouldnt say thats gosple, but its a pretty good guide for the ones ive changed recently, RWD tdci injectors do tend to last alot longer than FWD's for some reason :?
coconut
Ford Technician
Postby martynx » Tue Mar 10, 2009 8:42 pm
Better take my IDS along to potential cars then & ask if i can connect it up :idea: wonder if they'd mind :?:
martynx
Postby motorsporttransit » Sun Mar 15, 2009 9:10 pm
The 135ps with the 6speed box and the big DANA rear axle is a strong beast when running but needs proper servicing to keep right.The biggest issue with them is the Delphi injectors and the engine harnesses which were maid in Turkey.The wirring quality is not very good and you develop a lot of injector circuit problems which short the high side drivers which cause the system to shut down.The way the system is originally calibrated (PCM software) you run RAIL-Pressures of 800-1200 bar normally and constantly around 1600-1880 bar under load,Delphi injectors don't like this and the seats at the fuel control chamber tend to fail much faster than normal (60,000-70,000 miles).Take your IDS along and look for injector driver faults,injector trim faults and injector correction out of range and rail pressure control faults.
When you hook up look at the the fuel control at idle,when these systems are working well,with all ancillaries turned off they will idle at 3.5-4.5 mg/str with fueling offsets of 2 mg/strk max,anything higher walk away.
'' on a technical visit to a dealership,as i did in my previous job,i saw one of these vehicles had a technician sitting on the side of his ramp crying''
V184_WRC....Diesels Torque More
diesel@advancedenginediagnostics.com
motorsporttransit
Postby winterheating » Sun Mar 15, 2009 9:23 pm
motorsporttransit wrote:The 135ps with the 6speed box and the big DANA rear axle is a strong beast when running but needs proper servicing to keep right.The biggest issue with them is the Delphi injectors and the engine harnesses which were maid in Turkey.The wirring quality is not very good and you develop a lot of injector circuit problems which short the high side drivers which cause the system to shut down.The way the system is originally calibrated (PCM software) you run RAIL-Pressures of 800-1200 bar normally and constantly around 1600-1880 bar under load,Delphi injectors don't like this and the seats at the fuel control chamber tend to fail much faster than normal (60,000-70,000 miles).Take your IDS along and look for injector driver faults,injector trim faults and injector correction out of range and rail pressure control faults.
would zero be good then :?: cos i'm sure thats what my injectors are running at, is that the cylinder balance :?:
winterheating
Postby motorsporttransit » Sun Mar 15, 2009 9:34 pm
IF your cylinder balancing off-sets are sitting at zero that's excellent but not common.
What is your spec vehicle ? and what tool are you using to look at the system ?
motorsporttransit
Postby winterheating » Sun Mar 15, 2009 9:55 pm
motorsporttransit wrote:IF your cylinder balancing off-sets are sitting at zero that's excellent but not common.
125tdci fitted into MK6 280 75ps FWD.
that was after i'd had my injectors recond and thought one had knacked up straight away, took it to the diesel specialists that did the injectors, they tested injectors again and said they where fine, put them back in and was still missing, put there delphi software on and showed me the readings all where at 0 apart from the no.3 cylinder, they said it must be my cylinder or piston.
checked the connections again and found a tiny bit of plastic had broke off letting the copper tabs move apart to much. soldered new plug on then all was fine all at 0.
winterheating
Postby motorsporttransit » Sun Mar 15, 2009 10:34 pm
The front wheel drive units are very smooth once the injectors are working correctly and the corrections are loaded properly.
I noticed you called it a 75ps (125 TDCI is 125PS),are you referring to the chassis.
Did your injector specialist explain the drive cycle to aid in injector corrections updates ?
motorsporttransit
Postby winterheating » Sun Mar 15, 2009 10:50 pm
motorsporttransit wrote:The front wheel drive units are very smooth once the injectors are working correctly and the corrections are loaded properly.
sorry what i meant was i fitted a 125 tdci(complete with looms PCM and insrument cluster) into my van that had original 75ps engine.
as for explaining drive cycle and correction updates, no they didn't, ....... but i'm listening :!:
winterheating
Postby winterheating » Tue Mar 17, 2009 1:54 am
motorsporttransit wrote:Did your injector specialist explain the drive cycle to aid in injector corrections updates ?
should i ask them about it then :?:
winterheating
Postby motorsporttransit » Wed Mar 18, 2009 11:03 pm
Yes you should,make notes on what they tell you and let me know.
motorsporttransit
Postby winterheating » Wed Mar 18, 2009 11:14 pm
motorsporttransit wrote:Yes you should,make notes on what they tell you and let me know.
can you not tell me what i should here of them :?: :wink:
winterheating
Return to Buyers Guide
