Engine Power
Engine Power
Postby Dave91 » Fri May 15, 2009 10:57 am
Hi, I was looking at a Y plate MK6 Transit but need help knowing what power the engine is? I know later vans have it on the door eg 115 T350. This van is a LWB twin wheel dropside with a 2.4 dura-torq, how do I tell how much power it is?
If it can't be held with a cable tie or a ratchet strap nothing will hold it.
MK6 2001 2.4 LWB twin wheel dropside. The rustiest Mk6 in Britain?
Dave91
Re: Engine Power
Postby BigNeil » Fri May 15, 2009 11:00 am
it should still tell you on the door or put reg number here and someone will tell you
BigNeil
Re: Engine Power
Postby Altransit » Fri May 15, 2009 2:59 pm
BigNeil wrote:it should still tell you on the door
The early ones didn't always have the plate on the front doors, but mostly the 2.4 LWB seem to be 90ps
Re: Engine Power
Postby Dave91 » Fri May 15, 2009 4:22 pm
Hi, the reg is Y841 RJM
Dave91
Re: Engine Power
Postby sc_BK » Fri May 15, 2009 11:47 pm
It's a 90ps with 5.13 axle, if you're looking at other vans aswell all the info is available for free at https://www.etis.ford.com/
sc_BK
Return to Buyers Guide
