BigNeil wrote:was it a long cube / highcube
or just a lwb
ginsambo wrote:Is a longcube the same wheelbase as a normal lwb chassis cab then, equivalent to a chassis cab + extended frame hanging over the back?Think the wheelbase on my chassis cab is about 3.5 metres.
Backbone of Britain wrote:Longcube is in my avatar.
vitoansit wrote:Backbone of Britain wrote:Longcube is in my avatar.
Thats the one,thanks for that.I see in the info that Guy88 kindly put up for me that it is 76PS with a final drive ratio of 5.14 Am I right in assuming that it will be quite high revving on M/ways at about 70mph,what kind of mpg can I expect?
Thanks for all your replies.
BigNeil wrote:longcube is my avator too
it is as said above but it has the mk4 rear on it hence it over hangs in such a way.
I do miss my longcube for the length but not for the lack of turbo
ginsambo wrote:Backbone, is your Avatar stretched slightly??
