landrover with Di engine year??
Postby climbingchris » Wed May 10, 2006 5:17 pm
Any ideas What year/type this would be from?
Cheers
Chris
climbingchris
Postby MrMPuk » Wed May 10, 2006 6:08 pm
What is that engine fitted in? Looks like an early 90s to me.
Postby 100ps_drw_hicube » Wed May 10, 2006 6:20 pm
landie by the looks of it!! s2/3? :?
100ps_drw_hicube
Transit Abuser!!
Postby climbingchris » Wed May 10, 2006 8:42 pm
I'm afraid so,it's a series 3 I bought it a couple of weeks ago with the engine fitted, I know nothing of the engines history ie what year transit it came out of, so buying filters and parts is a bit awkward.
Hope you don't mind a small green interloper.
climbingchris
Postby Luke » Wed May 10, 2006 8:43 pm
climbingchris wrote:I'm afraid so,it's a series 3 I bought it a couple of weeks ago with the engine fitted, I know nothing of the engines history ie what year transit it came out of, so buying filters and parts is a bit awkward.
there should be the yaer cast into the head under the top hose!!! :D
Postby Luke » Wed May 10, 2006 8:45 pm
also ive split this from the origanal thread - i think there may be some non standard parts on and it may cause confusion!!! :D
Postby motorwise » Wed May 10, 2006 9:53 pm
shouldn't have too many problems with filters - all DI oil filters are the same - to identify the fuel filter, if it's got a plastic collar on it's '98 on, if it hasn't it's an early one - the air filter may cause a problem but it's probably the standard landie one plumbed in - if you're in doubt about anything on it (timing belt for instance) just get the number off it and your factor will be able to cross it over into something he stocks
looking at the fittings on it - stanadyne injectors, inlet manifold and thermostat housing design etc I'd guess it to be '89 - '91
http://www.motorwise.net
motorwise
Postby climbingchris » Thu May 11, 2006 8:53 am
Thanks for the help. It's been running rough intermittently, loosing all power, and going very lumpy. I finally got round to trying to work out how the fuel filter comes out last night when she flatly refused to go up any sort of hill. It's in a bit of an awkward place to get to but I found the drain screw on the bottom and emptied the filter, seems it was mostly filled with water. It had a collar around the filter housing that had a thumb screw to tighten it up to grip the filter, a bit like a jubilee clip, does this sound like a standard Transit fuel filter?
Also as someone reminded me, what sort of interval should timing belts be changed at on these engines and how difficult is it to do?
I don't know when it was last done so I should probably do it soon.
Thanks again
Chris
climbingchris
Postby Transitwalla » Thu May 11, 2006 9:26 am
ClimbingChris wrote; Also as someone reminded me, what sort of interval should timing belts be changed at on these engines and how difficult is it to do?
To me it really doesn't matter when the timing belt was changed . . anytime I get a new van I change the timing belt as a matter of course and write the date/mileage on the timing belt cover in correction fluid or on a sticky label.
How easy is it to do? It takes longer to remove the parts to get to the timing belt, than it does to replace it. The whole job for a first timer should take no more than 3 hours.
Oh . .and while the radiator is off . . flush it through.
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
Postby climbingchris » Thu May 11, 2006 12:15 pm
Right after having a bit of a search around here It doesn't seem to tricky to do the timeing belt, I'' try and get a kit and maybe have a go over the weekend.
climbingchris
Postby 100ps_drw_hicube » Thu May 11, 2006 2:57 pm
climbingchris wrote: It had a collar around the filter housing that had a thumb screw to tighten it up to grip the filter, a bit like a jubilee clip, does this sound like a standard Transit fuel filter?
yep sounds just like a standard fuel filter and housing :D it should be the one dated from 87 -97 they changed them late 97 ish :? :D
100ps_drw_hicube
Transit Abuser!!
Return to Buyers Guide
