by cross.damien » Fri Jan 15, 2010 5:16 pm
Hey thanks for the replies,
Ya you cant get a FWD Jumbo, so the toss up is between a FWD lwb high roof versus RWD jumbo high roof.
You have the extra length in the jumbo which is good for the camper, but the height is 100mm lower. However i can still stand up in the RWD that i have seen.
The traction is a problem when it is unladen im guessing, but as you say when the camper gear is in it, it should have enough weight over the back axle to give better traction.
Its certainly a tough call....am i missing anything?
Do the 04 RWD Jumbo transits have the same trouble with the fuel injection pump as i had with my 01 FWD? I had trouble with the Bosch pump as did everyone else i am sure, have these issues being sorted out on the 2004 model??
Any help is appreciated....
Damien
