whats it worth?
whats it worth?
Postby spoofer28 » Tue Mar 23, 2010 6:57 pm
need a bit of help im thinking of selling my van but duno what its worth?
its a P reg 100 lwb hi-top its just a ex-bt engine that had 78k when fitted and its done about 5k since fitting that vans showing 180ish when when engine was fitted it had a full service (all belts, filters, oils ect) 11months mot wich it passed no problems all that was said was one of the head lights was out of line, underneath is solid with only welding done to the rear cross member and handbrake mount, body work is again pritty much solid the only work are the front arches 1 started to show rust it that was ground down and sorted and the other arch had a bang in it where some kind person hit it, but when that work was done it wasnt painted the same shade and isnt the best job so that could do with redoing
so any thorts of what its worth?
older pics but all i have at the min
spoofer28
Re: whats it worth?
Postby spoofer28 » Wed Mar 24, 2010 8:29 pm
anyone??
spoofer28
Re: whats it worth?
Postby WildGoose » Thu Mar 25, 2010 7:46 pm
Prices vary with geographical region, so have you looked on autotrader for similar in your area?
It's worth whatever you can get someone to pay for it, is the simple answer. How long is a piece of string.
Unfortunately "not very much" is the case for most MK5's. Given that most Mk6's are getting so cheap now (for a reason of course :wink: ) there is no reason for the ill-informed to choose an older van like a 5.
Sorry I can't be more help.
WildGoose
Re: whats it worth?
Postby trustytransit » Thu Mar 25, 2010 10:30 pm
as above mate being a high top that will put some people off but id say 700-900
SMC PLASTERING 07717786982 READING BERKSHIRE
trustytransit
Re: whats it worth?
Postby trigger » Fri Mar 26, 2010 9:34 am
trustytransit wrote:as above mate being a high top that will put some people off but id say 700-900
High top would be most likely be bought by someone looking to build a camper
Mk5 Transit the daddy
trigger
Re: whats it worth?
Postby spoofer28 » Fri Mar 26, 2010 11:53 am
thats what i bought it for cos its the biggest you can get on a normal car mot (its the longest that will fit on a standard ramp and 100kg lighter than the max wight)
think ill stick it in the local paper for £1000 and if it go's it go's if it dont ill keep hold of it and turn it in to the camper
spoofer28
Re: whats it worth?
Postby trigger » Fri Mar 26, 2010 1:53 pm
Why don't you keep it and build that camper? the van looks pretty tidy for the year, if you build the camper well it would increase it's value several times over, then if you really NEED to sell you should make a tidy profit :D
trigger
Re: whats it worth?
Postby spoofer28 » Fri Mar 26, 2010 6:49 pm
cos i dont need it anymore, and ive got too many project on really to be starting another
and ive been offered a mint 4x4 cheap which at is more use to me at the min :wink:
spoofer28
Return to Buyers Guide
