Mk5 Model History
Mk5 Model History
Postby lolliedog » Thu Jun 24, 2010 3:41 pm
I am wondering what options are available in relation to Mk5 transits with regards wheelbase, Carring capacities and roof heights. I have looked for a model history but cant locate one on the net or forum.
Many Thanks
lolliedog
Re: Mk5 Model History
Postby madmark_50484 » Thu Jun 24, 2010 6:46 pm
You should have included that in the engine question never mind
SWB LWB for wheel base you also have the high cube and long cube still lwb but with extended body.
Then you have heights
No high roof, Semi high roof and high roof
The all wheel bases come with all roof heights
then you have the weights this a rough guide
80, 100, 120, 150, 190 its basically KGS x 10
eg 80 x 10 = 800 kgs
I believe Swb only goes to 120 Lwb only available from 100 though I could have that bit wrong.
What do you want your van for :?:
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Postby lolliedog » Thu Jun 24, 2010 7:35 pm
Sorry about not including this in my engine quetion. I am new to the forum. I only joined today.
The van will be used for light building work.
lolliedog
Postby MrMPuk » Thu Jun 24, 2010 7:53 pm
madmark_50484 wrote:No high roof
Or Low Roof as everyone else calls it.
madmark_50484 wrote:80, 100, 120, 150, 190 its basically KGS x 10
230
madmark_50484 wrote:I believe Swb only goes to 120 Lwb only available from 100 though I could have that bit wrong.
150 is in SWB.
Postby madmark_50484 » Fri Jun 25, 2010 8:46 am
Thats it couldn't think of the name
230
2.3 ton doesn't that go over 3.5 ton which would then mean you need a different licence :?:
150 is in SWB.
Thankyou now I know for next time someone asks
Past
Present
www.busesuk.co.uk
madmark_50484
Postby Altransit » Fri Jun 25, 2010 9:17 am
madmark_50484 wrote: 2.3 ton doesn't that go over 3.5 ton which would then mean you need a different licence :?:
That would depend very much on your particular licence, and whether the plated GVW is over 3500kg :D
Postby madmark_50484 » Fri Jun 25, 2010 9:42 am
Thats what I was getting at does the 230 go over the 3500 GVW if it does then if you passed your test after 1997 then you can't drive it with your licence
Past
Present
www.busesuk.co.uk
madmark_50484
Postby MrMPuk » Fri Jun 25, 2010 4:41 pm
That would be tonne not ton. Correct you would need class 3 to drive it on a post 97 license but they are a piece of piss to downrate.
Postby madmark_50484 » Fri Jun 25, 2010 8:37 pm
Excellent so would that be the DRW high cubes then :?:
Also assumably 1000 KGs = 1 Ton
what does 1 tonne weight :?:
Past
Present
www.busesuk.co.uk
madmark_50484
Postby madmark_50484 » Fri Jun 25, 2010 8:40 pm
Don't worry I just googled (took your other option :wink: )
1 ton = 1.016 tonnes you would have thought when they invented metric why didn't they give it a new name :?:
Past
Present
www.busesuk.co.uk
madmark_50484
Postby Altransit » Fri Jun 25, 2010 8:49 pm
madmark_50484 wrote: you would have thought when they invented metric why didn't they give it a new name :?:
They did :D and called it a metric tonne, rather than a ton :lol: :lol: :lol:
Return to Buyers Guide
